Have you Measured your Glass? July 11, 2014 09:18PM |
Re: Have you Measured your Glass? July 12, 2014 03:12AM |
Re: Have you Measured your Glass? July 12, 2014 03:49AM |
Re: Have you Measured your Glass? July 12, 2014 03:50AM |
Re: Have you Measured your Glass? July 12, 2014 05:18AM |
Re: Have you Measured your Glass? July 12, 2014 07:57AM |
Davek0974
That is an excellent point you note there, getting the x axis bearing runner surface as linear as possible is vital, I too have packed my rib with the shim tape at two points to do this. It is worth spending a lot of time on this matter as the positioning of the x axis runner in relation to the nozzle means every tiny undulation is amplified.
The good point is that once it's done with aluminium parts, it should not need doing again unless you have a very bad crash.
Re: Have you Measured your Glass? July 12, 2014 08:23AM |
colsenfoto
..What I forgot to mention was, that I no longer use the clamps, as they actually make the glass curve down at the corners. I have just taped the glass plate to the heating PCB with capton tape. It does not stick well, but as long as I have like 5 cm on all sides, the glass doesn't move. In this way, I can also use the whole bed - literally....
Re: Have you Measured your Glass? July 12, 2014 01:52PM |
Re: Have you Measured your Glass? July 12, 2014 11:41PM |
Re: Have you Measured your Glass? July 13, 2014 03:42AM |
Re: Have you Measured your Glass? July 13, 2014 06:04AM |
Re: Have you Measured your Glass? July 14, 2014 10:12AM |
