so I am trying to print a VERY small bridge...1.5cm
i have printed longer before but this particular file doesn't seem to want to print...
When I look closely it seems that what is happening is;
- as the nozzle beings the bridge there is very little extruded,
- as the nozzle is about half way over the bridge it begins extruding a lot heavier... the weight of this means the extruded material just remains on the nozzle tip until it reaches the edge and gets wiped off...
I have tried a slightly slower print, and a much slower print (Bridge print a 7mm/s).. still the same problem occurs.
Afterwards I tried just extruding the ABS manually. I can see the extruder gear turn but it takes about 1-2 seconds before any material comes out the nozzle. is this normal??
? could it be my nozzle is blocked? (once it's extruding it comes out fine and to the correct thickness..)
? could it be my nozzle temp isn't high enough? it's at 245°c
Sorry i don't have any images, I'm going to try the print again tonight and will get an image/video of the failure...
