Duet powering and unresponsive webinterface August 18, 2014 04:03AM |
Re: Duet powering and unresponsive webinterface August 18, 2014 04:33AM |
Re: Duet powering and unresponsive webinterface August 18, 2014 04:41AM |
Re: Duet powering and unresponsive webinterface August 18, 2014 05:02AM |
jstck
Regarding the web ui, in the last few versions I have sometimes had the Chrome tab freeze up, while the printer keeps going as normal. Just have to close the tab and reopen it (reloading the page does not seem to work). Not sure what causes it, but it's no big deal for me. All it does is mess up the remanining time estimates a bit. Not sure of the frequency of it, but I do think it happens for most long-running prints if I leave the browser tab open.
It has happened once or twice during gcode file upload as well, and the same "restart web page" has done the trick there too. I also deleted the "half-uploaded" files before re-uploading the couple of times this has happened.
Have not tried other browsers, using latest regular Chrome version on Mac.
Re: Duet powering and unresponsive webinterface August 18, 2014 06:39AM |
Re: Duet powering and unresponsive webinterface August 18, 2014 06:44AM |
jstck
Is there any useful status I can grab if it happens? Like telnetting to it and dumping something, or checking some particular javascript state in the browser?
Re: Duet powering and unresponsive webinterface August 18, 2014 07:03AM |
Re: Duet powering and unresponsive webinterface August 18, 2014 07:35AM |
droftarts
You may have missed this part of the commissioning instructions: [reprappro.com]
The important part is to put a jumper on the JP9 (5V_EN) pins. With USB disconnected, when you apply mains power you don't get a light on the board any more, as the LED that did come on was for the extra fan, which is now off by default in newer firmware. However, if you have ethernet plugged in, you'll get lights on the socket, and you should get the Y endstop light too, if the bed is away from the endstop.
jstck
Not sure if this is what you are experiencing, or if it is due to "uneven" power through USB. Does the Duet crash/restart when you do this, or is it just the web UI?
dc42
John, I too have noticed that web page reload has been less reliable recently and opening a new tab works better. There were a bunch of changes between 0.78h and 0.78i that may relate to this (i.e. 0.78i may have made things worse). If you have time, please can you try both versions and see if you can detect a difference.
Re: Duet powering and unresponsive webinterface August 18, 2014 07:41AM |
Re: Duet powering and unresponsive webinterface August 18, 2014 07:54AM |
Re: Duet powering and unresponsive webinterface August 18, 2014 08:08AM |
Re: Duet powering and unresponsive webinterface August 18, 2014 08:38AM |
