bad contact header connectors on DUET board December 19, 2014 08:05PM |
Re: bad contact header connectors on DUET board December 20, 2014 04:27AM |
Re: bad contact header connectors on DUET board December 20, 2014 04:45AM |
Re: bad contact header connectors on DUET board December 20, 2014 06:00AM |
Re: bad contact header connectors on DUET board December 20, 2014 06:21AM |
Re: bad contact header connectors on DUET board December 20, 2014 07:14AM |
Re: bad contact header connectors on DUET board December 20, 2014 07:51AM |
Re: bad contact header connectors on DUET board December 20, 2014 07:52AM |
Re: bad contact header connectors on DUET board December 20, 2014 08:01AM |
dc42
...Once the lid is on the electronics box, that should provide protection against the wires being pulled. While you are running with the lid off, I suggest you cable tie the looms to whatever you can to minimise the risk of them getting pulled - especially the stepper motor leads...
Re: bad contact header connectors on DUET board December 20, 2014 08:10AM |
Re: bad contact header connectors on DUET board December 20, 2014 09:58AM |
Re: bad contact header connectors on DUET board December 20, 2014 10:18AM |
M1k3l
@DC42, I will contact support because I do not want to blow by DUET board by any chance. The connectors to not grip wel enough, and I need to push the connectors of the y-endstop and the temperature to get a valid reading. I do not even have enough fingers free to hold/push all the connectors.
razzadazzas
how do you remove the crimped bit from the connector housing?
Re: bad contact header connectors on DUET board December 20, 2014 10:31AM |
Re: bad contact header connectors on DUET board December 20, 2014 12:54PM |
Re: bad contact header connectors on DUET board December 21, 2014 05:34AM |
Re: bad contact header connectors on DUET board December 21, 2014 06:07AM |
Re: bad contact header connectors on DUET board December 21, 2014 06:31AM |
Re: bad contact header connectors on DUET board December 21, 2014 07:06AM |
Re: bad contact header connectors on DUET board December 21, 2014 07:19AM |
Re: bad contact header connectors on DUET board December 21, 2014 08:56AM |
Re: bad contact header connectors on DUET board December 21, 2014 10:13AM |
Re: bad contact header connectors on DUET board December 21, 2014 11:37AM |
Re: bad contact header connectors on DUET board December 21, 2014 11:44AM |
Re: bad contact header connectors on DUET board December 21, 2014 12:39PM |
Re: bad contact header connectors on DUET board December 21, 2014 03:03PM |
dc42
The 0.6 revision number only refers to the revision of the printed circuit board. There are variations of that board with different connectors and/or terminal blocks soldered in.
Re: bad contact header connectors on DUET board December 21, 2014 04:57PM |
Re: bad contact header connectors on DUET board December 22, 2014 02:56AM |
Re: bad contact header connectors on DUET board December 22, 2014 04:15AM |
Re: bad contact header connectors on DUET board December 22, 2014 05:27AM |
Vizual54
My nozzle temperature reading seems be weird, reporting values 3.7° and 8.4° every other. Heated bed seems fine and is reporting ~20°.
My board did not have the 4.7k resistors which seems odd since its its a new kit ordered last week. Is it possible to add this for more accurate temp reading?
Re: bad contact header connectors on DUET board December 22, 2014 05:34AM |
