New firmware 0.96i December 10, 2014 06:28AM |
- The web inteface won't report a file is being printed when a single macro file is being executed (unless it's called from a real G-Code file of course)
- Cleaned up some parts of the networking code
- Minor change: debugPrintf does no longer allocate memory dynamically
- Bug fix: When a print is cancelled, the right (untransformed) coordinates will be set internally
- Bug fix: Fixed an issue where some moves were occasionally ignored by the Move class
Re: New firmware 0.96i December 10, 2014 02:43PM |
zombiepantslol
I know RRP has already released version 0.99 on their dev branch, but most of their changes are related to 3-nozzle printing and I don't want to deal with this at the moment. I also noticed they introduced M571 and that they kind of abuse the cooling fan pin for their purposes, which is why I don't want to merge in their current implementation into my fork. I may have a look at a customized version sometime soon, though. Well, perhaps I don't need to deal with their web interface changes anyway, because I've been thinking of writing my own web interface, which should provide support for multiple tools (depending on the machine's setup), spool management and a better layout on mobile devices. I'll see when I get time for this, but it's definitely on my TODO list.
zombiepantslol
Oh, and I finally decided to get a Simplify3D license - it actually looks quite promising, but as I've been waiting for my new alu plate to arrive, I can't report anything in detail at the moment. At least their "Extruder ooze rate" feature looks great, with that option enabled I get much nicer surface finishes than with Slic3r or Cura. And of course their support feature is great, I hope this will make it much easier to print more complex parts.
Re: New firmware 0.96i December 11, 2014 08:09AM |
Re: New firmware 0.96i January 03, 2015 12:33PM |
Re: New firmware 0.96i January 03, 2015 01:46PM |
Re: New firmware 0.96i January 03, 2015 06:09PM |
Fpex
Is there any firmware supporting the duex4? Would love to run the e3d kraken in the ormerod!
Re: New firmware 0.96i January 03, 2015 06:28PM |
Re: New firmware 0.96i January 03, 2015 06:36PM |
Re: New firmware 0.96i January 03, 2015 06:39PM |
