looking at getting an Ormerod 2, how do people like it? January 27, 2015 12:49PM |
Re: looking at getting an Ormerod 2, how do people like it? January 27, 2015 03:52PM |
Re: looking at getting an Ormerod 2, how do people like it? January 27, 2015 04:22PM |
Re: looking at getting an Ormerod 2, how do people like it? January 27, 2015 04:29PM |
dmould
I also purchased a 30A 12V PSU (sold for LED lighting - look on ebay) as I could crank it up to 14V to get faster bed heating for ABS, because a PC PSU struggles to achieve the required 110 deg C (but gets there eventually).
Re: looking at getting an Ormerod 2, how do people like it? January 27, 2015 04:33PM |
shadow651
I'm looking at getting a 3D printer, and am considering getting the Ormerod 2.
shadow651
I've got a friend who has a flashforge dreamer who can make the PLA parts for me. I'm mainly looking to PLA prints as a hobbyist, but I want the expandability to add another extruder or other modifications as time goes on. I have quite a bit of technical experience, I've assembled computers from parts and can do a fair bit of programming. Looking through the assembly instructions I don't see anything I can't handle.
shadow651
Anyways I'm looking for what people think of this printer. Common issues, hints for assembly, advice, how's their technical support, etc....
shadow651
Also, I emailed RepRapPro and they told me their printed parts are PLA with 20% infill (I'm assuming line infill?) Anyone know how thick of a shell is best (I'd assume something that makes gear teeth solid)? And is there any advantage to making the infill higher, especially for the hothead parts (say 40%)?
shadow651
Sorry about all the questions, but I'd like to be reasonably informed about the printer I'm looking at getting.
Re: looking at getting an Ormerod 2, how do people like it? January 27, 2015 05:03PM |
Re: looking at getting an Ormerod 2, how do people like it? January 28, 2015 08:25AM |
dc42
dmould
I did a similar upgrade with a 25A PSU on my Ormerod 1. The Ormerod 2 already comes with a similar 20A PSU. I'm not sure that this would be adequate for a dual nozzle machine, but RepRapPro should be able to tell you.
tstone
I would also recommend ordering an 0.3 nozzle for finer prints.
dc42
You might be interested in my comparison of the Ormerod and Mini Kossel kits at [miscsolutions.wordpress.com].
Re: looking at getting an Ormerod 2, how do people like it? January 28, 2015 09:55AM |
shadow651
Would I actually just order a One-piece stainless nozzle and Tapered brass M5 nut or would it be a second hot end to swap out? And how hard is it to swap nozzles? I assume in the software you just have to change a number in the config.g file and probably slic3r settings, but It's hard to tell how much of the hot end has to be disassembled to swap the nozzle, at least looking at the pictures in the assembly instructions.Quote
tstone
In here you mention that the Z-rod needs to be replaced every so often, or that you can put in a brass z-nut and replace that. Has this been improved in the second version any? and how often would you say you have to replace this? Also, how easy is it to locally source the rod or nut? I live in the US and shipping can take a while and cost a bitQuote
dc42
Re: looking at getting an Ormerod 2, how do people like it? January 28, 2015 12:23PM |
If you plan to switch often i would recommend get two hotends, this can be replaced with two screws.Quote
shadow651
tstone
I think rods shouldn't be too hard to get locally. If its this weird non metric stuff you probably have to change some factors in the config? Also if you maintain the rod with oil i think it will still last a little even with bed support running.Quote
shadow651
Re: looking at getting an Ormerod 2, how do people like it? January 28, 2015 01:24PM |
Re: looking at getting an Ormerod 2, how do people like it? January 28, 2015 02:25PM |
tstone
Re: looking at getting an Ormerod 2, how do people like it? January 28, 2015 02:41PM |
dmould
tstone
The extra hotend will need to have its own cold block, Bowden tube with fittings, and its own heater & thermistor wired to a plug to make swapping reasonably quick (I think it would then be 4 screws? Two holding the hot block to the X carriage and two holding the fan, heatsink and cold block) You could then swap the Bowden tube at the extruder end, which is much easier than at the hotend.
Dave
Re: looking at getting an Ormerod 2, how do people like it? January 28, 2015 02:53PM |
Re: looking at getting an Ormerod 2, how do people like it? January 28, 2015 02:57PM |
Re: looking at getting an Ormerod 2, how do people like it? January 28, 2015 03:29PM |
Re: looking at getting an Ormerod 2, how do people like it? January 29, 2015 11:53AM |
Re: looking at getting an Ormerod 2, how do people like it? January 29, 2015 12:46PM |
jsv555
Having played around with both nozzle sizes I decided that 0.5mm was my preferred nozzle. As stated the reduction in print speed compared with the marginal improvement in print quality didn't seem worth it to me.
In my opinion you get a much better improvement in quality refining your print settings (bit of an art in itself) so that the correct amount of filament is being extruded than you do by going down to a smaller nozzle size.
Re: looking at getting an Ormerod 2, how do people like it? January 29, 2015 01:17PM |
dmould
jsv555
Many people tend to equate nozzle diameter with pixel size on a screen or dot size on a conventional printer, and think that smaller=better. In fact the comparison is completely false for several reasons, one being that 3D printing does not involve any form of greyscale, and the other, as said, is that nozzle size does not affect the positional resolution. A diagonally printed line on a paper printer is composed of a string of separate pixels (dots) and so large pixels will make the line come out as rough and jagged, but a line printed on a 3D printer is solid and straight with no discontinuities and will be smooth and almost exactly the same no matter what the size of the nozzle (so long as its width is >= nozzle diameter).
Nozzle size is more akin to the nib size of a pen. You would not want to use a very fine nib for most things, and it certainly will not make your writing look any neater - a fine nib is only of advantage if you want to write extremely small lettering, and similarly a small nozzle is mainly only required for printing small objects that have fine detail.
Dave
Re: looking at getting an Ormerod 2, how do people like it? January 31, 2015 06:38PM |
Re: looking at getting an Ormerod 2, how do people like it? February 01, 2015 07:17AM |
dmould
You can slice a part so that the outer perimeters get printed with a thin layer height, but the inside infill is only printed every N layers (at N times the height of course). This gives a good compromise between finish and print speed.
Dave
Re: looking at getting an Ormerod 2, how do people like it? February 01, 2015 07:49AM |
appjaws1
dmould
Dave
Dave, how exactly do you set this up in slic3r and simplify3d?
