Something bad happens when I use the duet _Expansion board April 20, 2015 06:54AM |
Re: Something bad happens when I use the duet _Expansion board April 20, 2015 07:51AM |
Re: Something bad happens when I use the duet _Expansion board April 20, 2015 08:09AM |
Re: Something bad happens when I use the duet _Expansion board April 20, 2015 08:52AM |
sevenljy
But I can rise the temperature stably.It goes bad only when the temperature get reached.
I will still try your advice.thank you.
Maybe you can give me other reasons or advices?
Re: Something bad happens when I use the duet _Expansion board April 20, 2015 10:09AM |
Re: Something bad happens when I use the duet _Expansion board April 20, 2015 09:46PM |
Re: Something bad happens when I use the duet _Expansion board April 21, 2015 03:07AM |
sevenljy
I left it turned off and only control the E1 extruder.Is this a problem?the E0 works well.
Re: Something bad happens when I use the duet _Expansion board April 21, 2015 09:19AM |
Re: Something bad happens when I use the duet _Expansion board April 21, 2015 10:49AM |
Re: Something bad happens when I use the duet _Expansion board April 21, 2015 10:14PM |
Re: Something bad happens when I use the duet _Expansion board April 22, 2015 03:52AM |
Re: Something bad happens when I use the duet _Expansion board April 22, 2015 04:13AM |
