Updating Ormerod 1 with RRP 4-wire modulated proximity probe September 23, 2014 10:28AM |
What's the advantage of the new modulated proximity probe, as supplied with the Ormerod 2? Can I update my Ormerod 1 with the new probe?
>>>G31 SENDING:G31 245 (318)The first figure is the modulated reading, which is what the firmware uses. The second reading is the response including ambient IR, and is the reading you would get without the modulated probe. You can switch between the two modes using M558 P1 and M558 P2 to compare.
G91 G1 Z5 F200 G90 M558 P1 ; uncomment this line for Ormerod 1 upgraded with 4-wire probe G1 X-240 F2000 S1 G92 X0 G1 X3 F200 G1 X-30 S1 G92 X0 M558 P2 G91 G1 Z-5 F200 G90The edited homeall.g will look something like this:
G91 G1 Z5 F200 G90 M558 P1 ; uncomment this line for Ormerod 1 upgraded with 4-wire probe G1 X-240 F2000 S1 G92 X0 G1 X3 F200 G1 X-30 S1 G92 X0 M558 P2 ; uncomment this line for Ormerod 1 upgraded with 4-wire probe G1 X60 F2000 G92 Y0 G1 Y250 F2000 S1 G92 Y200 G1 Y197 F200 G1 Y250 S1 G92 Y200 G1 Y0 F2000 G30 G1 Z5 F200 G1 X0 Y0 G1 Z0
Re: Updating Ormerod 1 with RRP 4-wire modulated proximity probe September 23, 2014 01:09PM |
Re: Updating Ormerod 1 with RRP 4-wire modulated proximity probe February 12, 2015 01:21PM |
Re: Updating Ormerod 1 with RRP 4-wire modulated proximity probe February 12, 2015 04:08PM |
Re: Updating Ormerod 1 with RRP 4-wire modulated proximity probe February 12, 2015 08:38PM |
Re: Updating Ormerod 1 with RRP 4-wire modulated proximity probe February 13, 2015 03:16AM |
Re: Updating Ormerod 1 with RRP 4-wire modulated proximity probe February 13, 2015 06:58AM |
Re: Updating Ormerod 1 with RRP 4-wire modulated proximity probe February 13, 2015 08:29AM |
Re: Updating Ormerod 1 with RRP 4-wire modulated proximity probe February 13, 2015 08:48AM |
Re: Updating Ormerod 1 with RRP 4-wire modulated proximity probe February 13, 2015 10:08AM |
Re: Updating Ormerod 1 with RRP 4-wire modulated proximity probe February 13, 2015 02:13PM |
Re: Updating Ormerod 1 with RRP 4-wire modulated proximity probe March 06, 2015 06:29AM |
Re: Updating Ormerod 1 with RRP 4-wire modulated proximity probe March 06, 2015 10:51AM |
Mr_Bodge_It
Hello, I've bought the updated RepRap IR sensor board.
When I printed off the new X-carriage from the link above it became apparent that there are two problems...
1) The bearing mount is at 90o to the original. I've machined it to mount it orientated correctly - leading to...
2) The bearing is too far away from the X rib.
Doh!
Does anyone know if there is a modified X-carriage for the new IR sensor, or do I even need it?
Re: Updating Ormerod 1 with RRP 4-wire modulated proximity probe March 06, 2015 12:13PM |
ormerod168
Yes that look a bit strange, I think its supposed to run the bearing under the x-axis-plate (on lower edge of)
[attachment 50556 ormerod1_x-carriage_diff1.JPG]
Ah, mine doesn't look that pretty - there was some infill printed at the point where the bearing should be housed.
I shall give it another go and update my progress.
Many thanks for your time Erik
Re: Updating Ormerod 1 with RRP 4-wire modulated proximity probe March 10, 2015 12:28PM |
Re: Updating Ormerod 1 with RRP 4-wire modulated proximity probe March 10, 2015 01:17PM |
droftarts
Sorry, that seems to be a version that the designer was messing around with that's been updated to the repository a few days ago. I'll get this change reverted. For now, you can get the production version here: [github.com]
Direct link to file: [github.com]
Ian
RepRapPro tech support
Re: Updating Ormerod 1 with RRP 4-wire modulated proximity probe March 11, 2015 06:50AM |
Re: Updating Ormerod 1 with RRP 4-wire modulated proximity probe March 11, 2015 08:11AM |
dougal1957
Ian When are you likely to get more Duet's in stock I Need one to help test the CoreXY functionality in DC42's firmware fork?
Re: Updating Ormerod 1 with RRP 4-wire modulated proximity probe March 11, 2015 08:35AM |
dc42
dougal1957
Have you tried Think3DPrint3D to see if they have any in stock? Their price for a Duet was a few pounds less than RRP last time I looked. OTOH their boards come with screw terminals unless things have changed recently, and I prefer the Molex connectors on the RRP boards.
Re: Updating Ormerod 1 with RRP 4-wire modulated proximity probe April 25, 2015 04:14AM |
