Why did slicer do this... May 19, 2015 05:27PM |
Re: Why did slicer do this... May 19, 2015 05:32PM |
Re: Why did slicer do this... May 19, 2015 05:34PM |
Re: Why did slicer do this... May 19, 2015 06:48PM |
Thanks, yes, support was enabled but I didn't expect the solid vertical beams outside the holes. It's been a total nightmare to remove them.Quote
Darathy
i belive you have supports enabled in slic3r, it will fill the holes to make easyer bridging on top of the hole and keep dimensions.
Re: Why did slicer do this... May 19, 2015 06:50PM |
Re: Why did slicer do this... May 20, 2015 12:50AM |
Re: Why did slicer do this... May 20, 2015 08:55AM |
Re: Why did slicer do this... May 20, 2015 09:13AM |
Re: Why did slicer do this... May 20, 2015 10:36AM |
Radian
Thanks for the tip Dave. The obvious question is why a wide bridge across the rectangular cutout would be more successful than the attempt at a steep overhang. However, the cumulative curling-up that seems to result from too steep an overhang may be the answer as it can get into a right mess!
Re: Why did slicer do this... May 20, 2015 02:29PM |
dmould
...What should also work but I have not seen tried is to direct a stream of hot air downwards from above onto an overhang, which should either lessen the curl-up or cause it to curl down instead (which like a bridge tends to be self-healing). I may try using a hot-air gun on a low heat setting to baby my next print that has an overhang and see whether it works. The air should not be hot enough to melt the plastic, just hot enough to keep the top surface as hot as the bottom surface of the overhang.
Re: Why did slicer do this... May 20, 2015 07:13PM |
overhang_angle = 45; circle_dia = 10; difference () { cube ([circle_dia*2, circle_dia, circle_dia*2]); translate ([circle_dia, -1, circle_dia]) rotate ([90,0,180]) teardrop (circle_dia, circle_dia+2, overhang_angle); } module teardrop (dia, length, angle) { linear_extrude(height = length ) { union () { circle (d=dia, $fn = dia*4); polygon ([ [sin(90-angle)*-dia/2,cos(90-angle)*dia/2], [0,dia/2/sin(angle)], [sin(90-angle)*dia/2,cos(90-angle)*dia/2]], convexity = 10); } } }
Re: Why did slicer do this... May 20, 2015 07:27PM |
overhang_angle = 45; circle_dia = 10; difference () { cube ([circle_dia*2, circle_dia, circle_dia*2]); translate ([circle_dia, -1, circle_dia]) rotate ([90,0,180]) teardrop (circle_dia, circle_dia+2, overhang_angle); } module teardrop (dia, length, angle) { linear_extrude(height = length ) { union () { circle (d=dia, $fn = dia*4); polygon ([ [sin(90-angle)*-dia/2,cos(90-angle)*dia/2], [tan((90-angle)/2)*-dia/2,dia/2], [tan((90-angle)/2)*dia/2,dia/2], [sin(90-angle)*dia/2,cos(90-angle)*dia/2]], convexity = 10); } } }
Re: Why did slicer do this... May 21, 2015 04:10AM |
Well I never. That has to be the first time a company logo has been inspired by a shortcoming of the technology it employs.Quote
droftarts
On the subject of horizontal holes, and dealing with an overhang, the other option is to go up at an angle to a point. It's what the original reprap logo is supposed to show, rather than a 'drop' of melted filament, as is often assumed!
Re: Why did slicer do this... May 21, 2015 08:02AM |
droftarts
A further improvement would be to flatten the point, and bridge across at the top of the circle, like dmould suggests, but a bit more elegant - sorry, Dave!
Re: Why did slicer do this... May 21, 2015 08:13AM |
Radian
I noticed that the side of an object cooled by the vents pointing at the nozzle was doing a clean overhang yet the opposite side (sheltered from the vents) was curling up - so I grabbed another 40mm fan mid way through the print and positioned it to blow on the overhang.
