New experimental firmware 1.09a-dc42 May 17, 2015 04:54PM |
Merged in zpl's latest changes to Network and Print Monitor modules. DHCP and Netbios names are now supported (thanks RRP/zpl)
Added command M999 S4321 to unlock flash memory, reset and boot to BOSSA port
Z dive height is now relative to Z probe trigger height and the default is reduced to 3mm. As before, you can use the M558 H parameter to adjust it.
Added experimental support for an acoustic Z probe for delta printers (Z probe type 5)
Bug fix: when using a simple modulated IR probe, very high readings were occasionally read (this fix was in 1.04g which I didn't officially release)
Bug fix: the firmware once again prevents Z homing before X and Y are homed, if the Z probe is used for Z homing
Various code tidying
Re: New experimental firmware 1.09a-dc42 May 17, 2015 06:15PM |
dc42
- Support for swapping thermistor channels over
Re: New experimental firmware 1.09a-dc42 May 19, 2015 03:04PM |
zombiepantslol
I haven't forgotten about your Move improvements either, it's just the fact that they're quite vast which means I'll definitely need some more time to get them sorted. But I'll gratefully adopt your improvements when I find time, IMO your new move code does run a lot smoother than the old DDA implementation! When I find some more time, I think I will add a facility to utilise your M37 code on the web interface, too.
Re: New experimental firmware 1.09a-dc42 May 19, 2015 03:38PM |
Re: New experimental firmware 1.09a-dc42 May 19, 2015 04:08PM |
Re: New experimental firmware 1.09a-dc42 May 20, 2015 06:41AM |
shadow651
DC42, did you ever get a chance try and reproduce my M226/M24 pause resume problem?
I haven't had a chance to see if the new 1.09a has this issue or not, but I'll let you know when I get a chance to update the firmware.
Re: New experimental firmware 1.09a-dc42 May 20, 2015 11:42AM |
dc42
shadow651
I'm sorry, I forgot about it. Can you remind me what the problem was?
I did take a look at the code, and it appears that the only difference between M226 and M25 is that M226 waits for all previous moves to complete first - which makes sense, because it is intended to be used within the gcode file being printed.
Re: New experimental firmware 1.09a-dc42 May 20, 2015 12:51PM |
shadow651
The issue was that M226 seemed to pause fine, but when M24 is sent to resume, the printer tries to go beyond the axis limits, physically hitting the ends. I think it was trying to go X high and Y low but not sure.
It's strange because M25 pause and M24 resume works fine. For whatever reason it seems to not know where it's going for a resume from M226.
Re: New experimental firmware 1.09a-dc42 May 24, 2015 12:33PM |
Re: New experimental firmware 1.09a-dc42 May 24, 2015 01:42PM |
Sardi
Hey Dave.
I am planing on upgrading my firmware from current 0.78v to 1.04f. Is there anything else I need to change/add/erase/replace when upgrading? Any new lines to my config.s or can I just upgrade and leave everything as it is?
Re: New experimental firmware 1.09a-dc42 May 24, 2015 01:57PM |
Re: New experimental firmware 1.09a-dc42 May 24, 2015 03:50PM |
Treito
Which firmware release introduced the new connection for the distance sensor? And which version needed to turn the X-axis motor?
Re: New experimental firmware 1.09a-dc42 May 24, 2015 03:52PM |
Re: New experimental firmware 1.09a-dc42 May 25, 2015 04:04AM |
dc42
5. RepRapPro changed the standard tool numbering. The new standard is that the first head is tool 0. You don't have to make this change immediately, but once you are settled with 1.09, it's probably a good idea. This affects the M563 and G10 commands in config.g, and the T command in your slic3r start gcode.
6. By default, no tool is selected when the machine start up, so you need to send T0 (or T1 if you are using the old tool numbering) before you can extrude or heat up the hot end.
HTH David
Re: New experimental firmware 1.09a-dc42 May 25, 2015 04:39AM |
Sardi
So I change the P1 at commands M563 and G10 to P0?
Sardi
And that also means that I dont have to add T1 manually to my CURA exported g-codes?
Re: New experimental firmware 1.09a-dc42 May 25, 2015 09:02AM |
Re: New experimental firmware 1.09a-dc42 May 31, 2015 03:40AM |
Re: New experimental firmware 1.09a-dc42 May 31, 2015 04:50AM |
mirkov
I've updated from an old dc42 firmware (0.x) to 1.04f and 1.09, tested with old and new sys/www folders but I can't connect to the web interface anymore.
The OM1 does work via arduino/serial monitor, I just can't access to web interface.
oliveD-image mirko$ telnet 10.0.0.5 80
Trying 10.0.0.5...
telnet: connect to address 10.0.0.5: Operation timed out
telnet: Unable to connect to remote host
The web interface worked fine just before updating the firmware and the sdimage. (I have tested with the old folders)
Any ideas?
Re: New experimental firmware 1.09a-dc42 May 31, 2015 04:54AM |
dc42
Two things to check:
1. If you connect Pronterface as soon as you run the printer on or reset it, or alternatively turn the printer on with the network cable disconnected, connect Pronterface, and then connect the network cable, you should see the message "Network up, ip=###". Do you, and it so, it is the IP address you are expecting?
2. Can you ping the printer at the IP address you are expecting?
Re: New experimental firmware 1.09a-dc42 May 31, 2015 04:04PM |
Re: New experimental firmware 1.09a-dc42 May 31, 2015 04:07PM |
Re: New experimental firmware 1.09a-dc42 May 31, 2015 04:51PM |
Treito
Do you have (added) these lines in your config.g?
M563 P0 D0 H1 ; Define tool 1 G10 P0 S0 R0 ; Set tool 1 operating and standby temperatures
Re: New experimental firmware 1.09a-dc42 May 31, 2015 04:54PM |
Re: New experimental firmware 1.09a-dc42 May 31, 2015 07:01PM |
mirkov
Could you please tell me what's wrong with this code?
I've tested many variants but I only get this:
21:33:03 Error: Attempting to extrude with no tool selected.
21:32:59 Error: Setting temperature: no tool selected.
Re: New experimental firmware 1.09a-dc42 June 01, 2015 07:34AM |
Re: New experimental firmware 1.09a-dc42 June 01, 2015 12:35PM |
Re: New experimental firmware 1.09a-dc42 June 02, 2015 12:50PM |
Re: New experimental firmware 1.09a-dc42 June 02, 2015 03:18PM |
mynamesriz
Hi Dave,
I'm thinking of getting a second paneldue for my second (smaller) setup but am thinking of a smaller screen for this one, are you still supporting the Itead 3.2 screen? and if you are would something like the link below theoretically work as it uses the same drivers?
(http://www.ebay.co.uk/itm/3-2-TFT-Display-Touch-Panel-PCB-262K-Color-screen-MicroSD-SSD1289-Arduino-TE175-/400916125089?pt=LH_DefaultDomain_3&hash=item5d587695a1)
Thanks
Riz
Re: New experimental firmware 1.09a-dc42 June 04, 2015 07:07AM |
Re: New experimental firmware 1.09a-dc42 June 04, 2015 03:03PM |
