New firmware 1.09a-zpl June 10, 2015 06:57AM |
Introduced new Makefile for Linux and OS X, and a basic PowerShell compile script for Windows
- "make" and "make all" compile the firmware
- "make upload" resets the Duet via 1200BPS touch (only *nix-based OSs) and uploads firmware binary via bossac
- "make clean" purges the build directories
- Designed for Arduino 1.6.4 in conjunction with my Arduino board files (see Hardware directory)
Updated README file
Implemented M404 (filament width and nozzle diameter)
Added proper IsPrinting interface to PrintMonitor class
M24/M32 use the stack when a new file print is being started
M552 reports both the configured and actual IP addresses
Merged in (potential) fix for modulated Z probe filter (thanks dc42)
Made Z height detection more robust [G91/G90 is now checked]
Added experimental support for KISSlicer STABLE
Decreased file info scan length at the end of a file from 200K to 128K (appears to be sufficient)
Bug fix: T0 could not be used in config.g
Bug fix: FTP did not work if IP address was obtained via DHCP
Bug fix: Fixed and tested network disable/enable feature
Bug fix: Filament-based estimation occasionally returned bad time values at the end of a print
Bug fix: rr_connect returned an error message if a very long HTTP request was passed
Re: New firmware 1.09a-zpl June 20, 2015 06:25AM |
08:41:11 G28 Z Error: Push(): stack overflow!- After some time if I cancel a print and try to restart it the print does not start. I have to cancel the print again (in this case the head is not moving) and to restart the print.
; RepRapPro Ormerod ; Standard configuration G Codes M111 S0; Debug off M550 POrmerod; Set the machine's name M551 Preprap; Set the password M540 P0xBE:0xEF:0xDE:0xAD:0xFE:0xED ; Set the MAC address M552 P192.168.178.14; Set the IP address M553 P255.255.255.0; Set netmask M554 P192.168.178.1; Set the gateway M555 P2; Emulate Marlin USB output M92 E420; Set extruder steps/mm G21 ; Work in mm G90 ; Absolute positioning M83 ; Extrusions relative ;M574 X0 Y2 Z0 S1 ; set endstop configuration (Y endstop only, at high end, active high) M558 P1 ; Turn Z Probe on M305 P0 H14 L-11 ; set ADC correction M305 P1 H14 L-11 ; set ADC correction ;G31 Z2.1 P600 ; Set Z probe height and threshold Blue Tape ;G31 Z1.4 P500 ; Set Z probe height and threshold Glass ;G31 Z1.6 P500 ; Set Z probe height and threshold Glass alternative ;G31 Z0.6 P610 ; Set Z probe height and threshold Glass G31 Z1.4 P470 ; Set Z probe height and threshold BuildTak M906 X800 Y1000 Z800 E1000 ; Motor currents (mA) M201 X800 Y800 Z15 E1000; acceleration tweaks for improved finish M203 X15000 Y15000 Z250 E3600; speed tweaks for improved finish M569 P0 S0 ; Reverse the X axis ;M556 S78 X-0.63 Y1 Z-0.3 ;M556 S77 X0.25 Y0.5 Z-1 ;M556 S77 X0.75 Y0.5 Z0.25 M556 S79 X0.0 Y-0.25 Z-0.625 M566 X200 Y200 Z30 E20 ; Minimum speeds mm/minute M208 X210 Y200 ; set axis travel M208 X-5 Y0 S1 ; set axis minimum ;G30 P0 X60 Y20 Z-0.039 ;G30 P1 X60 Y180 Z0.447 ;G30 P2 X180 Y180 Z2.947 ;G30 P3 X180 Y20 Z2.845 S ;T0 M563 P0 D0 H1 ; Define tool 1 G10 P0 S0 R0 ; Set tool 1 operating and standby temperatures ;T0 ;End of config
; Ormerod 1 homeall file for use with dc42 Duet firmware ; Adjust the bed upper and lower limits in config.g (M208 commands) to get the correct homing positions G91 G1 Z4 F200 G1 X-240 Y240 F3000 S1 G1 X4 Y-4 F600 G1 X-10 Y10 S1 G90 ; Adjust the XY coordinates in the following to place the IR sensor over a suitable spot ; If you are using a dc42 IR sensor then you can change the coordinates to be near the centre of the bed G1 X45 Y0 F2000 G30 ; This file leaves the head at the zprobe trigger height so that you can slip a piece of paper under it and then do G0 Z0 to check the height. ; If you prefer to send the printer to X0Y0Z0, un-comment the following lines ;G1 X0 Y0 F5000 ;G1 Z0
G91 G1 Z3 F200 G90 G1 X130 Y80 F12000 G30
Re: New firmware 1.09a-zpl June 20, 2015 09:42AM |
Re: New firmware 1.09a-zpl June 21, 2015 02:55AM |
