Different Duet boards and different boot times? October 25, 2015 10:14AM |
Re: Different Duet boards and different boot times? October 25, 2015 10:52AM |
Re: Different Duet boards and different boot times? October 25, 2015 10:55AM |
Re: Different Duet boards and different boot times? October 25, 2015 11:06AM |
Re: Different Duet boards and different boot times? October 25, 2015 12:11PM |
Re: Different Duet boards and different boot times? October 25, 2015 01:32PM |
Re: Different Duet boards and different boot times? October 25, 2015 01:39PM |
Re: Different Duet boards and different boot times? October 25, 2015 07:02PM |
Re: Different Duet boards and different boot times? October 26, 2015 01:42AM |
Re: Different Duet boards and different boot times? October 26, 2015 09:08AM |
Re: Different Duet boards and different boot times? October 26, 2015 10:20AM |
Re: Different Duet boards and different boot times? October 26, 2015 12:38PM |
Treito
Many thanks that you take such a look at the schematic. Wow.
To your last idea: If there would be such a resistive leakage I would run in trouble even during printing. But it is not so.
Re: Different Duet boards and different boot times? October 26, 2015 12:53PM |
Re: Different Duet boards and different boot times? October 27, 2015 12:14AM |
Re: Different Duet boards and different boot times? October 27, 2015 08:26AM |
Treito
So there is no easy chance to grab this signal for scope purposes?
Re: Different Duet boards and different boot times? October 27, 2015 08:37AM |
Re: Different Duet boards and different boot times? October 27, 2015 09:04AM |
Treito
I am not happy to hold a small testpin anywhere at the board especially the ATSAM and to use the scope soft at the same time. The risk of Interruption of the signal is high or a can short cut two pins if I glitch from a pin. As you said the pins of the Duet are only 0.2mm wide. That is not an easy task so I would like to grab the signal. I do not know if my clamps can hold on adiode. Maybe it is possible maybe not, but the ATSAM? No way. Sorry.
Edit: What about the expansion pin header? It seems that the first four pins nearly offers my all that I want.
Re: Different Duet boards and different boot times? October 27, 2015 09:19AM |
Re: Different Duet boards and different boot times? October 27, 2015 09:40AM |
Treito
I would grab the voltages and the CPU reset pin from the expansion header. But it seems that nearly all boards are effected. There is no need to grab the signal to the Ethernet port as also the USB connection is delayed, too.
Re: Different Duet boards and different boot times? October 27, 2015 10:04AM |
Re: Different Duet boards and different boot times? October 31, 2015 10:26PM |
Re: Different Duet boards and different boot times? October 31, 2015 10:34PM |
Re: Different Duet boards and different boot times? November 01, 2015 01:05AM |
Re: Different Duet boards and different boot times? November 01, 2015 02:01AM |
