homing problems November 24, 2015 01:40PM |
Re: homing problems November 24, 2015 01:58PM |
cua193
The x homing is very strange, it's now just rising as it should, moving 5mm away from the motor then lowering - no movement at all toward the motor. It's completely ignoring the majority of the batch file. I've tried another SD card in case it was that - exactly the same. If I repeat the homing command it just ends 5mm further away. I can still move the carriage in both directions using Pronterface. The y homing is not affected. All motors are set at 1000. The bed levelling won't work as the x & y homing hasn't worked.
Re: homing problems November 24, 2015 02:25PM |
Re: homing problems November 25, 2015 11:55AM |
