Exploding Fuse January 30, 2016 02:48PM |
Re: Exploding Fuse January 30, 2016 03:11PM |
Re: Exploding Fuse January 30, 2016 03:19PM |
Re: Exploding Fuse January 30, 2016 04:06PM |
Re: Exploding Fuse January 30, 2016 05:18PM |
Re: Exploding Fuse January 30, 2016 05:23PM |
Promethus
I will check the wiring from the IEC connector to the PSU, but surely, the fuse would not of blown until the rocker switch on the IEC connector was flipped if the wiring was incorrect?
Re: Exploding Fuse January 30, 2016 06:02PM |
Promethus
Has anyone got any suggestion on how to fix the Duet board?
Re: Exploding Fuse January 30, 2016 07:27PM |
Re: Exploding Fuse January 30, 2016 09:00PM |
Promethus
Hi
I received an Ormerod RepRapPro 2 for Christmas and I have been putting it together every weekend since. I have just got to the stage in the instructions for testing the heaters. I had connected the power cable but when I switched it on at the socket the fuse immediately exploded, the rocker switch on the PSU was in the off position, tripping the RCD for all the sockets in the house. I reset the RCD in the house, and rebooted the computer, now though the Duet is no longer detected by Windows. So whatever went wrong appears to have fried the circuit board, the little led but lights up but that is all.
First of all does anyone know what caused the fuse to explode?
Does anyone know what fuse I need to replace the one that exploded?
Is there anyway to resurrect the Duet board?
I must say that I am not impressed with this 3D printer, having had broken parts on arrival, missing parts, and cables that were not properly terminated, and after all that now this.
Thanks
John
Re: Exploding Fuse January 31, 2016 01:36AM |
bartdietrich
I blew the RCD while assembling my second Ormerod too. It turned out to be because when I pushed the wired socket into the aluminium enclosure, the wires bent in such a way that the earth sheath contacted the neutral pin. This tripped the RCD as soon as an energized mains lead was connected to the Ormerod. Had it contacted the live pin instead, chances are some thermal damage would have occurred before the RCD was tripped. This doesn't really explain why your fuse blew though...
Re: Exploding Fuse January 31, 2016 03:57AM |
Re: Exploding Fuse January 31, 2016 04:34AM |
Re: Exploding Fuse January 31, 2016 04:39AM |
Re: Exploding Fuse January 31, 2016 04:56AM |
Re: Exploding Fuse January 31, 2016 04:59AM |
Re: Exploding Fuse January 31, 2016 05:27AM |
Re: Exploding Fuse January 31, 2016 05:56AM |
Re: Exploding Fuse January 31, 2016 06:28AM |
Treito
Why do you think Replikeo has a high failure rate?
Re: Exploding Fuse January 31, 2016 12:01PM |
Re: Exploding Fuse January 31, 2016 12:44PM |
Promethus
Well I got the parts from Maplin. It also appears that the 10amp fuse in the 3 pin plug was also killed. I have taken on your suggestion orictosh, to test the PSU, however I don't like you methodology, chopping of connectors and direct wiring, sounds kinda dangerous to me.
Promethus
Anyway, I connected the power, no explosion this time, and tested the DC end, which my multi-meter reported as 12.1V which looks right. So I tried connecting the Duet, and powered it up. There was a bit of a smell from the PSU at first, but soon dissipated. After about 2 minutes there was another smell, I could not work out where it was coming from, until I saw a wisp of smoke from the USB connection. I switched it off and started looking around the board with my IR thermometer; the USB connector was at over 40C, there was also another part of the board that was over 60C, a little black component, to the right of the heated bed terminal (I don't know what the component is called)
The new IEC has a proper cover on the back, and I have also covered the DC output cable from the PSU in heatshrink so there should be no more shorts, and I have purchase a new Duet from Replikeo. At least it will get me going, until the v0.8.5s come back in stock.
Re: Exploding Fuse January 31, 2016 04:52PM |
Re: Exploding Fuse February 01, 2016 08:34AM |
