Ormerod 2 bed sensor February 04, 2016 05:45PM |
Re: Ormerod 2 bed sensor February 04, 2016 07:03PM |
Re: Ormerod 2 bed sensor February 04, 2016 11:20PM |
Re: Ormerod 2 bed sensor February 05, 2016 02:06AM |
Re: Ormerod 2 bed sensor February 05, 2016 03:46AM |
Re: Ormerod 2 bed sensor February 05, 2016 01:02PM |
Europa
Yes I do mean homing the z axis and I am quite familiar with how to do it. sometimes I will need to change the values 4 or 5 times during an evening of printing, I naturally write the new values to the config file, it will always need to be done again the next day.
Treito makes an interesting point, calibrate the nozzle height when hot, I will give this a try. ABS does need a different setting as he says.
Has anyone fitted the dc42 sensor board? I was thinking of getting one of them but they look quite complicated to setup and of course are £50!!
Many thanks,
Brian
Re: Ormerod 2 bed sensor February 05, 2016 01:16PM |
Re: Ormerod 2 bed sensor February 05, 2016 01:52PM |
Re: Ormerod 2 bed sensor February 05, 2016 04:48PM |
Re: Ormerod 2 bed sensor February 06, 2016 03:58AM |
Re: Ormerod 2 bed sensor February 06, 2016 09:02AM |
Re: Ormerod 2 bed sensor February 06, 2016 12:56PM |
Re: Ormerod 2 bed sensor February 06, 2016 04:26PM |
Re: Ormerod 2 bed sensor February 06, 2016 05:31PM |
dc42
Yes I make the Ormerod-specific boards when I have enough orders to justify the time it takes to make a batch. I carry the mini board in stock because it is much more popular and is included by T3P3 and E3D in their 3D printer kits.
To use the mini board on an Ormerod 2, somebody would need to design a printed or easily-fabricated mount to fit it on the Ormerod hot end. I don't have an Ormerod 2 so I can't do this.
You can order the mini board from my site escher3d.com.
Re: Ormerod 2 bed sensor February 06, 2016 05:35PM |
Re: Ormerod 2 bed sensor February 06, 2016 10:37PM |
orictosh
Here is photo of the location of the z-probe upon a ormerod 2
[attachment 71965 Om2_probe_location.jpg]
After looking at your website, the PCB is mounted using the fan spacer/duct file, whereas on the Ormerod 2 it mounts into the x-carriage to the left of the hot-end assembly.
This probe also functions as the x-carriage end stop. Does your sensor perform this function?
The white sticky labels, seen at the corners improve the readings from the stock sensor.
Re: Ormerod 2 bed sensor February 07, 2016 02:22AM |
Re: Ormerod 2 bed sensor February 07, 2016 05:28AM |
dc42
To use my Ormerod board for X homing, you need to print a small homing pad to attach to the X motor mount. This is covered in the fitting instructions for the Ormerod board.
Re: Ormerod 2 bed sensor February 07, 2016 07:14AM |
Treito
dc42
Funnily I need this part also for the stock sensor. It seems that there is a small designing issue as the sensor board is a little bit displaced according the y-axis and so it misses the original sensor field by 2mm. It is triggered by the small diagonal area next to the original sensor area which means that the given value is only very small and the sensor is not fully triggered.
Re: Ormerod 2 bed sensor February 07, 2016 07:36AM |
dc42
The Ormerod hot end is designed to pivot about the X axis. It relies on the X arm being and remaining flat and straight so that the head remains vertical when the X runner bearing is correctly adjusted. With the acrylic X arm, I found that it was impossible to avoid a slight twist because of the force exerted by the weight of the head. So the head rolls a little as it moves along the X axis.
Re: Ormerod 2 bed sensor February 07, 2016 09:59AM |
Re: Ormerod 2 bed sensor February 07, 2016 10:20AM |
Re: Ormerod 2 bed sensor February 07, 2016 10:21AM |
Re: Ormerod 2 bed sensor February 07, 2016 10:22AM |
Europa
Am I correct in thinking that i will need to make a new nozzle mount that has the mini sensor on the left hand side so that it can still be used to home the X axis. I assume the X axis printed bit that the old sensor moves across will need to be extended as well as the mini sensor is a wider board with the critical part in the middle.
I am just about to fit my Chinese E3D V6 type hot end which I have printed a mount for but will now need to modify that if I am going with Davids mini sensor.
Re: Ormerod 2 bed sensor February 07, 2016 01:31PM |
Re: Ormerod 2 bed sensor February 07, 2016 04:07PM |
Re: Ormerod 2 bed sensor February 07, 2016 05:29PM |
Europa
Many thanks,
Brian
Re: Ormerod 2 bed sensor February 07, 2016 06:16PM |
Re: Ormerod 2 bed sensor February 07, 2016 06:18PM |
