100K Thermistor on Heat bed not working
Posted by minifiredragon
July 09, 2016 12:14AM
I self built an Ormerod 2 printer. In the processes I ordered to 100k thermistors missing the fact the bed was a 10k thermistor. I did not think it mattered, but it seems to as the Duet electronics reads the bed at -19. However, when I plug it into the hot head temp monitor it reads correctly.
I am running 1.14 dc42 firmware (just started commisioning the unit tonight). Is there a way I can tell the Duet to use the 2nd temp monitor for the bed temp? Or is there a place I can adjust or recompile a file to get it to work with the 100k thermistor? I assume the bed temp monitor is working because when I remove the wire it reads (I think) -64 (what ever it was, it was different then when it is plugged in).
Re: 100K Thermistor on Heat bed not working
July 09, 2016 06:30AM
Look for the M305 P0 command in config.g and change T10000 in that command to T100000 (or add T100000 if no T parameter is present). Also change the B parameter to the appropriate value for your thermistor. See [duet3d.com] for more.
Edited 1 time(s). Last edit at 07/09/2016 01:26PM by dc42.
July 09, 2016 12:45PM
Thanks for the help! I had looked at the config.g file and all the M305's were the same so I was scratching my head. Google does not help much for finding an answer like this. It is funny because I found the settings for the different thermistors, but did not find how to set them in the config.g or what ever file it needed.
Anyway, it is reading correctly now.
