So, CURA has an option thats called
shell thickness.
Ive read on many places over the web that the number of shell thickness should be divideable with your nozzle size.
My nozzle is 0.5 (ormerod 1), now, when I set shell thickness at 0.5 and print a wall thats 1mm thick i get 2 layers + some infill on some rounded parts.
When I set the shell thickness at 1mm i get only 2 layers (as i suppose it should be).
How come is that? If the wall is 1mm thick, shouldnt shell thickness of 0.5mm be enough for 2 layers one next to each other without any special infill?
