Any Ormerod oners from Cape Town? June 22, 2017 01:51PM |
Re: Any Ormerod oners from Cape Town? June 23, 2017 07:26AM |
Re: Any Ormerod oners from Cape Town? June 23, 2017 10:55AM |
Karoo Klong
Now the tool selection is still not active
....and my Y-Axis is inverted. But no matter how I incert the wireing of the code,
the printer still tries to find the limit switch for the Y-Axis on the opposite side.
Re: Any Ormerod oners from Cape Town? June 23, 2017 11:02AM |
Re: Any Ormerod oners from Cape Town? June 23, 2017 05:27PM |
Re: Any Ormerod oners from Cape Town? July 03, 2017 06:21PM |
Re: Any Ormerod oners from Cape Town? July 05, 2017 03:11PM |
Karoo Klong
Thank you so much for your help Erik.
I now only manualy evel the bed.
I used hairspray to get the prints to stick. My prints look rather crappy and it seems as if the nozzle is staging through the precious prints.
I have kind of lost my urge you want to print anymore.
I don't know or where and how to start fixing this problem.
I noticed that the spacer between the hotende and the x-carridge was charged down at an angle that was causing the sensor to knock the part as it was printing. I put a cardboard spacer in and then it seemed to work better.
Re: Any Ormerod oners from Cape Town? July 19, 2017 11:07AM |
Re: Any Ormerod oners from Cape Town? July 19, 2017 03:01PM |
Error: heating fault on heater 0, temperature excursion exceeded 15.0C
Re: Any Ormerod oners from Cape Town? July 20, 2017 03:14AM |
Karoo Klong
I have got the new aluminium X-Arm reinstalled now and I changed the design to be like it was in the Ormerod 1 where the rib actually grips the M5 nut, Since I cant successfully print yet that's the way I have to make things happen. I wonder why did they remove that nut grip on the Ormerod 2?
...(Since its winter here I cant seem to get the heated bed up to 110'C)
Re: Any Ormerod oners from Cape Town? August 04, 2017 07:47AM |
Re: Any Ormerod oners from Cape Town? August 04, 2017 02:32PM |
Re: Any Ormerod oners from Cape Town? August 04, 2017 03:12PM |
Re: Any Ormerod oners from Cape Town? August 07, 2017 01:47PM |
Re: Any Ormerod oners from Cape Town? August 07, 2017 03:46PM |
Re: Any Ormerod oners from Cape Town? August 12, 2017 01:18PM |
Karoo Klong
I tried to download a new Slic3r update but every single version I tried to download gave me this annoying error.
It seems Sli3r no longer allows you to download their software.
I still cant get my ABS to stay stuck.
So I very reluctantly mixed up some ABS slurry. but have not yet tested or used it.
Also I am contemplating what to do with the Duet housing as I cannot fit a fan cover with it in the way.
Re: Any Ormerod oners from Cape Town? August 21, 2017 11:37AM |
Re: Any Ormerod oners from Cape Town? August 21, 2017 01:16PM |
Re: Any Ormerod oners from Cape Town? August 25, 2017 02:55PM |
Re: Any Ormerod oners from Cape Town? August 29, 2017 10:07AM |
Re: Any Ormerod oners from Cape Town? August 29, 2017 11:49AM |
Karoo Klong
Its funny, I find it easier to upgrade this machine and to fabricate the parts myself that to actually make a design and have the printer print it for me
I have added the two silicone diodes as suggested by dc42 and boosted the voltage up all the way to 14.7 volt but I haven't yet tested how it affects bed heating.
There was a question I kept forgetting to ask.
In slicers they give the option of controlling fan speed, but I see no variance in fan speed of the hotend fan. Does it always only blow at one speed?
How do you connect a separate parts cooling fan and is it able to control that fan speed?
Re: Any Ormerod oners from Cape Town? October 24, 2017 07:20PM |
Re: Any Ormerod oners from Cape Town? October 25, 2017 02:57AM |
Re: Any Ormerod oners from Cape Town? October 25, 2017 05:38AM |
dc42
Regarding the LED, it probably couldn't handle 120C for long periods. It shouldn't be difficult to replace it. You could use a through-hole LED if you don't want to solder a SMD one.
Re: Any Ormerod oners from Cape Town? October 25, 2017 08:51AM |
Re: Any Ormerod oners from Cape Town? October 25, 2017 11:14AM |
dc42
Although the bed is at 120C, the general temperature within your enclosure should be much lower. I recommend that you keep the Duet below 50C is possible. Ideally the PSU and Duet would be outside the enclosure.
Re: Any Ormerod oners from Cape Town? October 25, 2017 01:19PM |
Karoo Klong
Any ideas on where I can find the Y-Axis bearing clamps for the Ormerod 1 please..
Re: Any Ormerod oners from Cape Town? November 01, 2017 03:59PM |
Re: Any Ormerod oners from Cape Town? July 25, 2018 12:53PM |
Re: Any Ormerod oners from Cape Town? November 14, 2018 05:39PM |
