Hi all,
I am about to replace my x-axis 5mm rod with an 8x8rod attached directly to the stepper motor.
Since Im using this sensor made by DC42 Im going to lose about 1cm of printing space near the Z axis since the X rod will be that closer to the printing plate. 1cm is not much now to think of it, but if I can make it not to lose any, why not.
I was thinking of puting a limit switch on the side where the sensor is now, and to move the sensor on the other side.
Will this combination work? And if yes, where do I plug the limit switch on the ormerod board? And do I need to add/remove/change anything to my config.g?
