Back again after 3 years December 18, 2018 05:44AM |
* Ormerod 1 with Duet v0.6 * RepRapFirmware 1.09c-dc42 * Web interface 1.06. * Aluminum bed support from DD Metal Products * Heated bed is 3mm aluminum PCB [www.reprap.me], with a layer of 200mm wide kapton, no glass plate * DC42's differential Z-sensor/hotend board * Brass long nut (on regular threaded rod) * Aluminum X-arm kit
Re: Back again after 3 years December 18, 2018 01:54PM |
Re: Back again after 3 years December 18, 2018 01:56PM |
Re: Back again after 3 years December 19, 2018 02:57AM |
Re: Back again after 3 years December 19, 2018 03:01AM |
Re: Back again after 3 years December 19, 2018 03:30AM |
spiff
What would be the best way to upgrade my old duet 0.6 firmware? I used bossac before, and I probably still have it installed on my PC
Re: Back again after 3 years December 19, 2018 08:50AM |
Firmware Name: RepRapFirmware for Duet Firmware Electronics: Duet 0.6 Firmware Version: 1.22 (2018-07-26b2) Web Interface Version: 1.22.3
Re: Back again after 3 years December 19, 2018 09:14AM |
Re: Back again after 3 years December 19, 2018 07:50PM |
Re: Back again after 3 years December 19, 2018 07:54PM |
Re: Back again after 3 years January 02, 2019 11:51AM |
Re: Back again after 3 years January 02, 2019 12:13PM |
Re: Back again after 3 years January 02, 2019 04:04PM |
Re: Back again after 3 years January 02, 2019 04:56PM |
Re: Back again after 3 years January 03, 2019 02:56AM |
spiff
Regarding the lower Z mount, I found this thread [reprap.org] , which describes a version made for cap head screws instead of countersunk. I think the reason why my part is splitting may very well be due to the countersunk screws, so I will try that first.
I did find this one also [www.thingiverse.com] , which is probably the chunkier version you mentioned.
Once again, thanks to everyone pitching in. This forum is really outstanding.
Re: Back again after 3 years January 03, 2019 08:39AM |
Re: Back again after 3 years January 03, 2019 10:37AM |
Re: Back again after 3 years January 03, 2019 12:00PM |
Re: Back again after 3 years January 07, 2019 02:12PM |
Re: Back again after 3 years January 08, 2019 03:51AM |
spiff
.. but so far I have tied a thin piece of wire around the x-carriage and into the groove on the bearing.
Then today I did a second attempt. Not quite sure what caused the problem this time. The print started out fine, but when I went to check on it after about an hour, it seems there had been a problem: The print head was moving around in the print like too much filament had been extruded (or the print head had not been lifted enough between layers). There had also been a bit of skipping in the Y-direction. Had to abort the print
Re: Back again after 3 years January 08, 2019 05:21AM |
ormerod168
Yes that's a bit strange, there should be no problems with curl-ups that early, only if the print itself lifted from the bed
ormerod168
The first print looks fine as far as it went but the picture seems to show a bit of curl-up at the pointy bit at the wall of the hole that could have grabbed the nozzle?, if so, more cooling to the print or/and a bit lower nozzle temp. would help
ormerod168
And no harm in raising the motor current settings a bit, standard was 800mA -
M906 X1000 Y1000 Z800 E1000 should be OK
Re: Back again after 3 years January 12, 2019 02:20PM |
