SD Card not working December 14, 2013 06:07PM |
Re: SD Card not working December 15, 2013 10:25AM |
Re: SD Card not working December 15, 2013 03:49PM |
Re: SD Card not working December 15, 2013 08:18PM |
Re: SD Card not working December 16, 2013 02:32AM |
Re: SD Card not working December 16, 2013 03:37AM |
The files are available hereQuote
Wolf1130
Hello,
my SD Card is empty. The linked drivers are not so good, of course windows 8.1 bring the message new keyboard/mouse found.
Worked 2 hours, but no network connection, no usb connection and no happyness.
There are so many drivers, software and other "helping" forum tips, why can nobody give the hole software in a file to download for a simpl user.
I don´t need troubeles, i will get started printing 3D without any problem.
Kurt
Re: SD Card not working December 16, 2013 11:03AM |
actiondrone
Hi
Try to use my new ormerod printer, number 002/500 by RS component
I cant read config file from the printer.
I read about someone have the solution with other card brand
Tryed other 8Gb sundisk, 2 Gb sundisk, 4Gb KingStone .... but don't solve my problem.
Tryed to reformatting in some PC/Mac but the error still present, also usind official SD formatting tools.
From pronterface I see the duet cant find the config.h file, but this file is good on sd card reading from pc windows.
obviously without config.g I cant connect with web interface and only green light on the ethernet port blink.
How can I solve it? How to check if duet have problem with every sd card?
Thanks
(From PronterFace)
Connecting...
T:32.5 B:-273.1
Printer is now online.
SENDING:M503
Can't open 0:/sys/config.g to read from. Error code: 3
Configuration file not found
Re: SD Card not working December 16, 2013 03:40PM |
Re: SD Card not working December 16, 2013 04:03PM |
Re: SD Card not working December 17, 2013 02:58AM |
droftarts
@rayedge - I've updated the instructions, as it seems for the moment, we aren't putting the files on the SD card. It would be ideal if we could, but you would have to change them yourself at some point anyway.
@actiondrone - This is a community forum, everyone is here to help everyone else, and no one is obliged to help. I am obliged to help, but I also have other responsibilities, and a limited amount of time. I know you have emailed reprappro support, and I am trying to get around to answering everyone's responses, but at this time of high demand, please be patient while we try and sort out problems that it's not very clear what the issue is.
The three possible problem areas for you are:
1. Failure of SD card - unlikely, you have tried other cards, reformatted etc.
2. Failure of SD adaptor - possible - have you tried a different USB to SD card adapter?
3. Corrupt download files - possible - how did you download the Github repository? You should click the 'Download ZIP' (or 'Clone to Desktop') button on the right of the page here: [github.com] . Don't download the files individually; often with Github files, unless you download 'Raw' versions, you get html documents. Then copy the contents of 'SD Image' to the SD card, so that you have three folders - gcodes, sys, www - with files in them, the most important being sys/config.g
4. Failure of Duet board SD reader - possible. No real way to test, and we haven't had any definitive reports of this, but I don't rule it out.
Without testing, it's difficult to say what part is failing, and what needs to be changed. This thread was started to try and collect some responses from people, to see if there is a common thread. Some have reported SD card failures, some adapter failures.
Generally, when we troubleshoot customer problems at RepRapPro, we try and find exactly what is wrong, and replace that specific part, if needed. Generally, this is the fastest way of resolving problems, though there may be some questions that need to be asked. If you feel it is the card, you can return it for a replacement, for which you are due - see this thread: [forums.reprap.org]
Ian
RepRapPro tech support
Re: SD Card not working December 17, 2013 03:05AM |
Re: SD Card not working December 17, 2013 03:13AM |
Re: SD Card not working December 17, 2013 03:20AM |
Re: SD Card not working December 17, 2013 03:35AM |
Re: SD Card not working December 17, 2013 07:44AM |
Re: SD Card not working December 17, 2013 08:04AM |
Re: SD Card not working December 17, 2013 08:20AM |
Re: SD Card not working December 19, 2013 04:29AM |
Re: SD Card not working December 20, 2013 01:34PM |
Re: SD Card not working December 20, 2013 02:13PM |
Re: SD Card not working December 20, 2013 03:49PM |
Re: SD Card not working December 21, 2013 05:41AM |
Re: SD Card not working December 21, 2013 01:56PM |
Re: SD Card not working December 21, 2013 02:31PM |
Re: SD Card not working December 21, 2013 03:54PM |
Re: SD Card not working December 24, 2013 09:26AM |
Re: SD Card not working December 27, 2013 10:24AM |
Re: SD Card not working December 27, 2013 12:37PM |
Re: SD Card not working December 28, 2013 10:46AM |
Re: SD Card not working December 28, 2013 06:18PM |
