Ormerod commissioning problems [SOLVED] December 20, 2013 05:14PM |
Re: Ormerod commissioning problems December 20, 2013 06:06PM |
Re: Ormerod commissioning problems December 20, 2013 06:38PM |
Re: Ormerod commissioning problems December 20, 2013 06:44PM |
Re: Ormerod commissioning problems December 20, 2013 07:00PM |
Re: Ormerod commissioning problems December 20, 2013 07:38PM |
- mine hits that target at around 3mm over kapton or 0.5mm over glue-smeared glass, it was up at around 7 or 8 mm over foil before I stopped using foil).Quote
G31 Z0.5 P500 ; Set Z probe height and threshold
Re: Ormerod commissioning problems December 20, 2013 08:50PM |
Re: Ormerod commissioning problems December 20, 2013 09:30PM |
Re: Ormerod commissioning problems December 21, 2013 12:15AM |
Re: Ormerod commissioning problems December 21, 2013 03:17AM |
Re: Ormerod commissioning problems December 21, 2013 07:29AM |
Re: Ormerod commissioning problems [SOLVED] December 21, 2013 08:40AM |
Re: Ormerod commissioning problems [SOLVED] February 03, 2014 06:33AM |
Re: Ormerod commissioning problems [SOLVED] February 03, 2014 06:39AM |
Re: Ormerod commissioning problems [SOLVED] February 03, 2014 06:50AM |
Re: Ormerod commissioning problems [SOLVED] February 03, 2014 06:54AM |
Re: Ormerod commissioning problems [SOLVED] April 09, 2014 05:27AM |
Re: Ormerod commissioning problems [SOLVED] April 09, 2014 06:41AM |
Sardi
Ive read this topic several times about, and cant help not to ask - regarding the Z probe -> am I going to have to adjust the probe every time before each print because the lightning has changed and the probe is recieving different readings?
Re: Ormerod commissioning problems [SOLVED] April 09, 2014 06:54AM |
Davek0974
Sardi
Have you got DC42's new probe board fitted??
If no then yes
If yes then no
Re: Ormerod commissioning problems [SOLVED] April 09, 2014 07:32AM |
dc42
Davek0974
If no then yes
If yes then no
...except that if your Ormerod is in a room lit by fluorescent or LED light, and there is little or no sunlight, then the original probe should give consistent readings.
Re: Ormerod commissioning problems [SOLVED] April 09, 2014 07:44AM |
Unfortunately I found that DC’s I.R. Probe wouldn’t work for me…But it could be a clash with the glass I use.Quote
Davek0974
Sardi
If no then yes
If yes then no
Re: Ormerod commissioning problems [SOLVED] April 09, 2014 07:50AM |
KimBrown
The Original probe works (and I’m currently using it) provided the machine isn’t in direct daylight. I use my printer in a number of different environments, each with different lighting levels.(The printer clocks up 1200miles a month traveling with me, and is used on-board ship for two Weeks of the month). I found I was getting good results by using 4mm Dark Red Float glass and no reflective tape/paper, which was giving reliable, repeatable readings. Normally I find that I can setup the printer, use Z-homing, and 9 out 10 times won’t have to re-adjust it. If I do end up doing it manually, then I get a probe average reading and either enter it manually, or edit the config file.
Kim..
Re: Ormerod commissioning problems [SOLVED] April 09, 2014 03:11PM |
Sardi
KimBrown
Kim..
Yes, but again - you changed the glass, DC changed the probe, a change is needed in order to get constant readings from the probe.
Im thinking about getting the probe from DC cause I dont want the nozzle crashing in my bed just because someone passed by the printer and blocked the light source.
Re: Ormerod commissioning problems [SOLVED] May 28, 2014 01:42PM |
Re: Ormerod commissioning problems [SOLVED] May 28, 2014 01:47PM |
Re: Ormerod commissioning problems [SOLVED] May 28, 2014 03:35PM |
Re: Ormerod commissioning problems [SOLVED] May 28, 2014 03:40PM |
Re: Ormerod commissioning problems [SOLVED] May 28, 2014 05:08PM |
