Fan assembly fouls on foldback clips December 21, 2013 03:26PM |
Re: Fan assembly fouls on foldback clips December 21, 2013 04:16PM |
Re: Fan assembly fouls on foldback clips December 21, 2013 04:51PM |
I don't recall adjusting mine so guess I was lucky, but perhaps you should check the slot clearance or enlarge?Quote
Fit the runner bearing using the M3x12mm cap head screw. The washer should be positioned between the bearing and the x-carriage. Check that the screw can move in the slot; this allow you to adjust the angle of the hot end.
Re: Fan assembly fouls on foldback clips December 21, 2013 04:58PM |
Re: Fan assembly fouls on foldback clips December 21, 2013 05:04PM |
Re: Fan assembly fouls on foldback clips December 21, 2013 06:56PM |
Re: Fan assembly fouls on foldback clips December 21, 2013 08:14PM |
Re: Fan assembly fouls on foldback clips December 21, 2013 08:35PM |
Re: Fan assembly fouls on foldback clips December 22, 2013 02:44AM |
Re: Fan assembly fouls on foldback clips December 22, 2013 06:08AM |
