Fan backwash causes warping? December 21, 2013 07:12PM |
Re: Fan backwash causes warping? December 21, 2013 08:27PM |
Re: Fan backwash causes warping? December 21, 2013 10:44PM |
Re: Fan backwash causes warping? December 22, 2013 03:32AM |
Re: Fan backwash causes warping? December 22, 2013 05:14AM |
Re: Fan backwash causes warping? December 22, 2013 05:59AM |
Re: Fan backwash causes warping? December 22, 2013 06:30AM |
Re: Fan backwash causes warping? December 25, 2013 11:55AM |
..how about this idea - afaik the static pressure will increase if you join two fans running counter clockwise, my logic tells me (but sometime fail me) that it also would have to reduce the backwash, if this works it will be a very easy fix without any change to the form factor, just two 10mm fans on top of each other instead of one 20mmQuote
reprappro
@dc42: We increased the size of the fan (from 40mm x 40mm x 10mm used on the Mendel/Huxley to 40mm x 40mm x 20mm) to increase the static pressure. The
Re: Fan backwash causes warping? December 26, 2013 10:13AM |
Re: Fan backwash causes warping? December 26, 2013 02:16PM |
Re: Fan backwash causes warping? December 26, 2013 03:42PM |
Re: Fan backwash causes warping? December 26, 2013 05:20PM |
Re: Fan backwash causes warping? December 26, 2013 06:39PM |
Re: Fan backwash causes warping? December 28, 2013 06:10AM |
markbee
So I took a piece of baking paper and some kapton tape and isolated the fan backwash (and of course to guarantee inlet air) to the top of the fan. No warping at all!
(WARNING! Be careful to copy my cheap workaround because you get in trouble when the carriage assembly homes to X!)
