pronterface connection problem
Posted by trevor51
December 22, 2013 10:25AM
I have followed the commissioning document and successfully completed the arduino tests. next step is running pronterface.
initial connection goes well and reports that the interface is up and running however all I get is a series of numbers prefixed by a T and a B which I presume are the head and bed temperatures running up the screen at approc a second interval. if I try to send M503 or request positions all I get is the 'printer is offline' message and the number continue to roll up the screen.
Any suggestions?????
Re: pronterface connection problem
December 22, 2013 10:45AM
Looks like you have the same problem I had, which is that config.g is not running at startup.
Workaround: press the Reset button on the Duet before trying to connect Pronterface.
Fix: ditch the SD card that came with the kit and substitute a decent one (I used a Maplin own-brand 4Gb class 10 card).
Edited 1 time(s). Last edit at 12/22/2013 10:46AM by dc42.
