I have an Ormerod kit number 122. I have experienced many of the problems catalogued here prior to the commissioning page being updated and figured out the ATX had to be running to get the board to function properly. I still have no network connection despite setting every thing up in the config file and manually adding the route via the DOS command line on my PC.
I am now stuck with a problem on the X axis. The homing procedure works fine and the print head stops homing flag (I have a piece of silver tape on it) but when I start printing the O position changes pushing the edge of the print area off the edge of the heat bed. When I stop the print by turning the ATX supply off and on again (the Pause print button in Pronterface has no effect) and send the x axis to 0 it has moved to midway in the travel.
Does anyone have an answer for this problem?
Dave M
Edited 1 time(s). Last edit at 12/23/2013 03:57AM by davem.
