questions about building - lnear bearings oil? and glue x-axis acrylic? December 26, 2013 05:37AM |
Re: questions about building - lnear bearings oil? and glue x-axis acrylic? December 26, 2013 07:36AM |
Re: questions about building - lnear bearings oil? and glue x-axis acrylic? December 26, 2013 08:04AM |
Re: questions about building - lnear bearings oil? and glue x-axis acrylic? December 26, 2013 08:14AM |
Re: questions about building - lnear bearings oil? and glue x-axis acrylic? December 26, 2013 09:07AM |
Re: questions about building - lnear bearings oil? and glue x-axis acrylic? December 26, 2013 09:33AM |
Re: questions about building - lnear bearings oil? and glue x-axis acrylic? December 26, 2013 09:49AM |
Re: questions about building - lnear bearings oil? and glue x-axis acrylic? December 26, 2013 10:00AM |
Re: questions about building - lnear bearings oil? and glue x-axis acrylic? December 26, 2013 11:05AM |
Re: questions about building - lnear bearings oil? and glue x-axis acrylic? December 26, 2013 11:08AM |
Re: questions about building - lnear bearings oil? and glue x-axis acrylic? December 26, 2013 12:34PM |
Re: questions about building - lnear bearings oil? and glue x-axis acrylic? December 26, 2013 12:52PM |
Re: questions about building - lnear bearings oil? and glue x-axis acrylic? December 26, 2013 02:55PM |
Re: questions about building - lnear bearings oil? and glue x-axis acrylic? December 26, 2013 05:12PM |
droftarts
2. Yes, put a little light oil in the bearings if you wish, and wipe the rods before assembly. Because we're using larger 12mm bearings, rather than 8mm bearings used on Mendel printers, they are generally more robust. A drop of oil on the bearings very occasionally will keep the rubber seal lubricated; they can dry out and increase friction. I must add a maintenance/improvements page to the instructions...
t
Re: questions about building - lnear bearings oil? and glue x-axis acrylic? December 26, 2013 05:26PM |
kwikius
Thanks for all the replies. Will try gluing my xaxis parts with cyano and see how that goes. One further question re lubrication..
droftarts
t
You say somewhere in the thread that you lubricate the bearings on your machines every couple of months. I have already partially assembled my machine. I assume its necessary to remove the bearings from the ground rods to lubricate them so do you actually strip down your machines every couple of months to lubricate the bearings?
I am assuming that adding some oil on the ground rods would only lubricate the oil seals.
regards
Andy
Re: questions about building - lnear bearings oil? and glue x-axis acrylic? December 27, 2013 04:57AM |
Re: questions about building - lnear bearings oil? and glue x-axis acrylic? December 27, 2013 05:55AM |
ormerod168
I would not worry about it, the bearings is in a closed system and the oil inside will last forever - just make sure to keep the sealing intact and the rods free from rust by adding a thin layer of oil now and then
Erik
Re: questions about building - lnear bearings oil? and glue x-axis acrylic? December 28, 2013 04:59AM |
Re: questions about building - lnear bearings oil? and glue x-axis acrylic? December 28, 2013 06:04AM |
Re: questions about building - lnear bearings oil? and glue x-axis acrylic? December 28, 2013 10:09AM |
Re: questions about building - lnear bearings oil? and glue x-axis acrylic? December 28, 2013 11:57AM |
ormerod168
kwikius
"..The brass parts and the bowden tube. I found this really tricky!.."
Me too, especially the lineup of the parts, ptfe is quite soft and if you start wrong seems to try to move "out of the tupe"
but thats an easy fix - inside diameter of the brass and tube is a bit over 2mm, a 2mm welding rod will fit right in, cut of 100mm of rod, buffed both end so not to scratch the ptfe
used the rod as a guide to line up the parts whilst screwing in the brass (see pic.)
and there is no need to clean out the pfte with a dril bit if you do it this way, the ptfe will "cold form" and stay put around the 2mm guiding rod, you have to use a lot of pressure though
Ian
"..Use a pencil sharpener to lightly.."
A kingdom for a pencil sharpener! - who has such a thing theese days he he...well, easy to make a poor mans version, (see pic.) and again the 2mm welding rod came in handy
Erik
. Once I have tried the printer out I will certainly give this a try. Just need some 2 mm rod!
