Instructions improvement suggestions December 28, 2013 05:42AM |
Re: Instructions improvement suggestions December 28, 2013 06:32AM |
Re: Instructions improvement suggestions December 28, 2013 06:35AM |
Re: Instructions improvement suggestions December 28, 2013 07:01AM |
kwikius
In Electronics para 2
"The M4x16mm countersunk screw goes through the lug on the side, again with a spacer and T-nut on it."
kwikius
In Hot end assembly > Final assembly > List of components at start
I believe the 16 mm screws should be listed as countersunk not cap head
Re: Instructions improvement suggestions December 28, 2013 07:02AM |
Re: Instructions improvement suggestions December 28, 2013 07:39AM |
Rory166
When fitting the z-axis sprocket please move description of whch way up it goes to the start of the section not near the end. I fitted it then read it should be other way up! I apreciate you do say thoroughly read and understand whole thing before starting, but even so this would help.
Re: Instructions improvement suggestions December 28, 2013 08:41AM |
Re: Instructions improvement suggestions December 28, 2013 08:49AM |
Re: Instructions improvement suggestions December 28, 2013 08:54AM |
Re: Instructions improvement suggestions December 29, 2013 06:01PM |
Re: Instructions improvement suggestions December 30, 2013 11:17AM |
i measure closer to 75 and I think this distance should be defined by pully / belt so should not really have that big a difference. maybe I did not measure correctly?Quote
Finally, measure the distance between the tip of the projection near the angled corner and the center of the end of the screw. This should be 78mm
Re: Instructions improvement suggestions December 30, 2013 11:22AM |
Re: Instructions improvement suggestions December 30, 2013 12:22PM |
Re: Instructions improvement suggestions December 30, 2013 05:54PM |
Re: Instructions improvement suggestions December 31, 2013 02:24AM |
Re: Instructions improvement suggestions December 31, 2013 04:20AM |
Re: Instructions improvement suggestions December 31, 2013 04:29AM |
Re: Instructions improvement suggestions December 31, 2013 05:06AM |
Re: Instructions improvement suggestions December 31, 2013 05:33AM |
hughesie
I removed the clip , did the axis compensation and then put the clip back on.
hughesie
Depending on the length of silver tape you have stuck to the glass you should be able to move the bed on the y axis so the head misses the clip.
H
Re: Instructions improvement suggestions December 31, 2013 05:35AM |
dc42
kwikius, the clips are not very satisfactory for holding the bed down because they get in the way of the head, the fan duct, and the sensor. See this thread for a better alternative.
Re: Instructions improvement suggestions January 04, 2014 08:41AM |
Re: Instructions improvement suggestions January 04, 2014 10:40AM |
Re: Instructions improvement suggestions January 04, 2014 10:53AM |
Re: Instructions improvement suggestions January 11, 2014 07:01AM |
Re: Instructions improvement suggestions January 11, 2014 07:09AM |
Re: Instructions improvement suggestions January 12, 2014 06:40AM |
Re: Instructions improvement suggestions January 12, 2014 05:01PM |
droftarts
Please post your feedback and/or suggestions for improvements of the instructions here, or email them to me on support at reprappro dot com
Thanks!
Ian
RepRapPro
Re: Instructions improvement suggestions January 13, 2014 08:14AM |
Re: Instructions improvement suggestions January 13, 2014 12:09PM |
kwikius
In the Hot end assembly section. I think a link to the drawing of the bowden end or a section through with PTFE bowden inserted and finished,would help greatly to help understand what we are trying to achieve. Will try and do a diagram and see if I have it right now!
regards
Andy
Re: Instructions improvement suggestions January 13, 2014 12:16PM |
