Re: Instructions improvement suggestions January 13, 2014 12:18PM |
Re: Instructions improvement suggestions January 13, 2014 01:42PM |
reprappro
The whole hot end section is due for a rewrite, with new pictures. It's quite easy to tell if you've gone far enough into the Bowden tube union; if you take the brass union back off, the thread on the PTFE should be 10mm long.
Ian
RepRapPro tech support
reprappro
PS Great picture, kwikius! The trouble is, most people can't see inside the brass union!
Ian
Re: Instructions improvement suggestions January 13, 2014 01:50PM |
Re: Instructions improvement suggestions January 13, 2014 02:03PM |
Treth
So is the inside of the union a counter sink?
I had presumed the pencil sharpener used on the end of the tube was just to get the thread started, but now see that the hole is drilled and will have a countersink.
My tube was simply slightly shaved and went in very easily, I did put a slight mark on the tube to check it went about 10mm and there have been no printing issues.
I haven't looked at the latest build instructions and as I started the beginning of December I guess these are now more detailed...
Yes, great picture kwikius, thanks.
Re: Instructions improvement suggestions January 13, 2014 03:01PM |
Re: Instructions improvement suggestions January 13, 2014 03:29PM |
Re: Instructions improvement suggestions January 13, 2014 05:31PM |
Re: Instructions improvement suggestions January 13, 2014 06:44PM |
Re: Instructions improvement suggestions January 14, 2014 03:40AM |
Printing from the SD card
You may have noticed that, so far, all printing is done from the SD card. This is the preferred way of printing. It is possible to print directly from Pronterface (ie load gcode files into Pronterface and press print), but the serial communication is slow. The printer will pause a lot during printing, and the printed part will not be of good quality.
Re: Instructions improvement suggestions January 14, 2014 03:51AM |
3D-ES
Hi Ian!
The printing instructions probably need to be updated:
I am happy to report that this no longer seems to be true
Re: Instructions improvement suggestions January 14, 2014 04:12AM |
Re: Instructions improvement suggestions March 02, 2014 04:09PM |
Re: Instructions improvement suggestions March 02, 2014 04:13PM |
Re: Instructions improvement suggestions March 02, 2014 04:21PM |
Re: Instructions improvement suggestions March 02, 2014 04:27PM |
KP
I'm convinced I found separate PDFs for each section on GitHub in the last two days but now I can't find them.
Kev.
Re: Instructions improvement suggestions March 02, 2014 04:45PM |
Re: Instructions improvement suggestions March 02, 2014 04:54PM |
Re: Instructions improvement suggestions March 03, 2014 08:54AM |
Re: Instructions improvement suggestions March 03, 2014 12:19PM |
Re: Instructions improvement suggestions March 04, 2014 06:39PM |
Re: Instructions improvement suggestions March 05, 2014 06:23AM |
Re: Instructions improvement suggestions July 15, 2014 12:06PM |
Re: Instructions improvement suggestions July 15, 2014 01:42PM |
