Fine threads and rough edges when printing December 29, 2013 08:15AM |
Re: Fine threads and rough edges when printing December 29, 2013 09:14AM |
Re: Fine threads and rough edges when printing December 29, 2013 10:56AM |
Re: Fine threads and rough edges when printing December 29, 2013 11:07AM |
Re: Fine threads and rough edges when printing December 29, 2013 11:08AM |
Re: Fine threads and rough edges when printing December 29, 2013 11:23AM |
Re: Fine threads and rough edges when printing December 29, 2013 11:35AM |
Re: Fine threads and rough edges when printing December 29, 2013 11:54AM |
Re: Fine threads and rough edges when printing December 29, 2013 12:06PM |
Length - The number of millimeters to retract. Note that the measurement is taken from the raw filament entering the extruder. A value of between 1 and 2mm is usually recommended. Bowden extruders may need up to 4 or 5mm due to the hysteresis introduced by the tube.
Re: Fine threads and rough edges when printing December 29, 2013 12:10PM |
Re: Fine threads and rough edges when printing December 29, 2013 12:48PM |
case 201: // Set axis accelerations for(int8_t drive = 0; drive < DRIVES; drive++) { if(gb->Seen(gCodeLetters[drive])) { value = gb->GetFValue(); }else{ value = -1; } platform->SetAcceleration(drive, value); } break; case 203: // Set maximum feedrates for(int8_t drive = 0; drive < DRIVES; drive++) { if(gb->Seen(gCodeLetters[drive])) { value = gb->GetFValue()*distanceScale*0.016666667; // G Code feedrates are in mm/minute; we need mm/sec; platform->SetMaxFeedrate(drive, value); } } break; case 205: //M205 advanced settings: minimum travel speed S=while printing T=travel only, B=minimum segment time X= maximum xy jerk, Z=maximum Z jerk break;
Re: Fine threads and rough edges when printing December 29, 2013 04:14PM |
Re: Fine threads and rough edges when printing December 29, 2013 04:18PM |
Re: Fine threads and rough edges when printing December 29, 2013 04:27PM |
Rory166
Not a "disaster darling" its a work of art. Call it "My Vision of Chaos" and enter it into next years Turner prize, should be a shoe in, don't forget I'm due a drink when you win the 25k prize.
Rory166
I have now completed a prototype deflector had intended to use aluminium but some clear plastic was the first thing that came to hand. At least you can see what it is, easier. There are 5 x 3mm washers under the plastic to retain the 2mm gap required the pk screw is self threaded into a few fins which were pre drilled to the apropriate size.
Rory166
Wish I new how to put photos in the text like you.
Re: Fine threads and rough edges when printing December 29, 2013 04:33PM |
droftarts
It looks like M201 and M203 are implemented, so you can change those on the fly, but not M205 (lines 1510 to 1535 [github.com] ):
Re: Fine threads and rough edges when printing December 29, 2013 06:18PM |
Re: Fine threads and rough edges when printing December 30, 2013 04:06AM |
Re: Fine threads and rough edges when printing December 30, 2013 04:37AM |
Re: Fine threads and rough edges when printing December 30, 2013 06:18AM |
(emphasis added)Quote
dc42
What I really want to do is print over Ethernet, or copy files to the SD card over Ethernet. I hope the firmware will be updated to provide this facility soon (if it isn't, I may add it myself).
Re: Fine threads and rough edges when printing December 30, 2013 07:37AM |
Re: Fine threads and rough edges when printing December 30, 2013 07:52AM |
Re: Fine threads and rough edges when printing December 30, 2013 08:15AM |
Re: Fine threads and rough edges when printing December 30, 2013 08:41AM |
