Extruder stuttering [SOLVED] December 30, 2013 11:32AM |
Re: Extruder stuttering December 30, 2013 11:42AM |
Re: Extruder stuttering December 30, 2013 11:56AM |
Re: Extruder stuttering December 30, 2013 12:43PM |
Re: Extruder stuttering December 30, 2013 12:48PM |
Re: Extruder stuttering December 30, 2013 02:12PM |
droftarts
Hmm... sounds like missed steps to me. Did you play with the acceleration or max axis speeds?
Ian
RepRapPro tech support
Maximum feedrates (mm/s):
M203 X500.00 Y500.00 Z5.00 E45.00
case 203: // Set maximum feedrates
for(int8_t drive = 0; drive < DRIVES; drive++)
if(gb->Seen(gCodeLetters[drive]))
value = gb->GetFValue()*distanceScale*0.016666667; // G Code feedrates are in mm/minute; we need mm/sec;
platform->SetMaxFeedrate(drive, value);
break;
Re: Extruder stuttering [SOLVED] December 30, 2013 02:38PM |
Re: Extruder stuttering December 30, 2013 03:45PM |
dc42
I think I found the immediate cause of the problem. The Z axis is not going up the correct distance between layers. The Ethernet interface said it was at 5.75mm but it was nothing like as high as that, more like 2mm. Now I just need to find out why that was.
Re: Extruder stuttering [SOLVED] December 30, 2013 04:17PM |
Re: Extruder stuttering [SOLVED] December 30, 2013 04:29PM |
