How do you abort a print and clear the buffer?
Posted by gregstah
December 30, 2013 01:59PM
How do you abort a print and clear the buffer if you see a print is going badly?
I can't seem to find a way to do this so I've been pausing prints then clicking the object to print again. Clearly it does not overwrite as I've just run out of webserver buffer...
I'm now getting "Max open file count exceeded"
Thank you.
Re: How do you abort a print and clear the buffer?
December 30, 2013 02:55PM
Lots of views and no response usually means I'm missing something totally obvious... am I?
December 30, 2013 03:12PM
Hi gregstah,
the "maximum open file count" error is fixed with the newest firmware which is just released about an hour ago.
If the print ist getting bad, I pause the print an then reprint from SD card. I only additionaly zero the Z-axis again.
Restarting the print in Pronterface is not possible yet (see some Pronterface issues here )
Markus
XBee & electronics blog: [lookmanowire.blogspot.com]
December 30, 2013 03:27PM
Thank you Markus, I thought I was missing something really obvious!
I'll load the new firmware, thank you for letting me know.
G
