Y-axis endstop black wiring connectors December 31, 2013 12:57PM |
Re: Y-axis endstop black wiring connectors December 31, 2013 01:07PM |
Re: Y-axis endstop black wiring connectors December 31, 2013 03:35PM |
Re: Y-axis endstop black wiring connectors December 31, 2013 04:01PM |
Re: Y-axis endstop black wiring connectors December 31, 2013 05:09PM |
JamesR10
They look like your suppose to attach a connector block to them and then to the terminal (they may have female pins), I have just tried to peel back the HS but it broke the terminal in half, but never mind.
I wondered about a male terminal plier crimped to the end stop, the just pushed onto that.
But I'm wondering what part it's supposed to be. Anyway I ran out of terminals by using the wrong ones first. It may be solder, but I need to sort a desk space first.
Thanks though.
Re: Y-axis endstop black wiring connectors December 31, 2013 07:54PM |
Re: Y-axis endstop black wiring connectors December 31, 2013 08:25PM |
Are you saying your machine has no serial number at all?
...this picture is worth a thousand words in terms of RRP's engineering design. Have you ever seen a sensor cable split to go both ways round a motor shaft and sprocket?
Re: Y-axis endstop black wiring connectors January 01, 2014 04:12AM |
This is to keep it simple, nothing to do with RRP's skills.Quote
I am sorry to say that in my over inflated egotistical opinion this picture is worth a thousand words in terms of RRP's engineering design. Have you ever seen a sensor cable split to go both ways round a motor shaft and sprocket? Can't say I have, wonder why that is?
Re: Y-axis endstop black wiring connectors January 01, 2014 07:06AM |
Re: Y-axis endstop black wiring connectors January 01, 2014 10:47AM |
Re: Y-axis endstop black wiring connectors January 01, 2014 02:38PM |
Re: Y-axis endstop black wiring connectors January 01, 2014 03:15PM |
