Fan backwash problem - new parts to fix
Posted by Rory166
Re: Fan backwash problem - new parts to fix
January 09, 2014 07:05AM
dc42
Andy, are you sure you have put the correct files in the zip? File fan_deflector_v4.scad contains this:
use <fan_deflector_v2_aerofoil.scad>
but the actual file supplied is fan_deflector_v4_aerofoil.scad
Thanks... just uploaded a corrected version so should be fixed now. In fact its the same file so you can just change that line to
use <fan_deflector_v4_aerofoil.scad>
regards
Andy
Edited 3 time(s). Last edit at 01/09/2014 07:07AM by kwikius.
Ormerod #318
www.zoomworks.org - Free and Open Source Stuff smiling smiley
January 12, 2014 12:38PM
I've just adapted Andy's design for my own Omerod. Mine has a 7-bladed fan with a larger hub. I also wanted to make it thin enough to slide behind the electronics box. I reasoned that not having the number of stationary blades the same as the number of fan blades would be likely to make the fan quieter, and after experimenting with the design, I settled on 9 stationary blades. I found the skirt that fits around the fan was too thin on the original and broke easily, so I thickened it by 1mm.
I have put the openscad and stl files here, and here is a photo of the installed fan inlet.
It seems to be working fine. The backwash is gone and the airflow at the front seems just as strong as before. If I print it again, I will reduce the size of the hub by 0.5mm or possibly 1mm radius. The blades are rather thin at their thinnest edge and there are some tiny gaps between a few of the filaments, so I think the blades could be a little thicker, or the print done in 0.12mm layers.
Edited 4 time(s). Last edit at 01/12/2014 12:40PM by dc42.
January 13, 2014 04:28AM
Hi DC42
Glad its working well smiling smiley
Running fan_deflector_v4.scad in openscad, it looks like the skirt needs a tweak to skim a bit more from the faces front and back. Patch attached:
fan_deflector_tweak.patch
BTW the thickness of the blades is controlled by the thickness parameter in module "aerofoil" in fan_deflector_v4_aerofoil.scad . The thickness parameter controls the ratio thickness / chord. Unfortunately changing thickness changes foil length slightly due to the changing diameter of the circle on the ends of the foil. Ideally the aerofoil foil should have a chord length of 1 but I just added the radius on the ends.
Some day will try to make everything a bit more generic .. and add some comments!
regards
Andy
Ormerod #318
January 13, 2014 06:37AM
I'll be printing one of these excellent mods asap, but since Markus pointed out the problem I've been using a much lower-tech solution (which has held up for a few hundred grams of ABS and is ultra-slimline). I applied a strip of Kapton tape across the lower part of the fan pictured printing a threadless ballscrew in ABS on Marley KS10 bed coating (there's some motion blur):
January 13, 2014 07:12AM
rayhicks
[attachment 24661 backwashmod.jpg]
Now I know that all the time I spent designing 5 different versions of the fan deflector was surely not wasted smiling smiley
regards
Andy
Ormerod #318
February 09, 2014 07:38AM
I had a problem with the tabs on the fan defector, they almost broke off after fitting and replacing it a few times. I printed a new one, but I couldn't get it on the fan without breaking two of the tabs. Maybe the 7-bladed fan I have has different dimensions from the 5-bladed one that I think Andy worked with. So I modified the design further to replacing the cap head screws that hold the hot end together by 50mm countersunk M3 screws, which go through the backwash plate. Here is a photo and the openscad file.
I don't really like using slotted screws, but they were all my local supplied had in 50mm M3 csk. I considered instead attaching the deflector to the two threaded brass bushes that my fan has in the top 2 holes, however they don't appear to be a metric thread, an M3 screw goes in them but gets stuck after a few turns.
open | download - FanDeflector.scad (3.2 KB)
February 09, 2014 07:20PM
I've completed and tested a "beta" version of a replacement one piece air duct for the hot end, I have rotated the heat sink by 90 degrees so the airflow is much more direct, meaning a slower, quieter, narrower fan can be used with similar air flow to the current design, backwash is nearly all eliminated, a fan cover is really only needed for finger safety now. It's also much easier to print and has better clearance over the print job. I'll post some pics after a few more tests.
Matt
Limited Edition Red RS Ormerod 1 #144 of 200 - RRP 1.09fw
iamburnys Ormerod Upgrades Github
Follow me on ThingiVerse My Designs
February 10, 2014 08:15AM
I thought I had printed the latest version but after printing it looks nothing like the green one on the recent posts. The one I printed has clips top and bottom and has 15 openings, looking like a fan. However, it does not quite fit width seems OK but the height is short. This may be my printer settings, I am re checking everything today and re-commissioning.
Could somebody provide the agreed best version in an stl file please.
Thank you
Paul
February 10, 2014 08:25AM
Paul, there are at least 2 different models of fan supplied with the kit, so I don't think a standard fan deflector design is possible. Andy's original one was I think designed for a 5-bladed fan. My fan has 7 blades and a larger central core, so it needed some design changes. Also I wanted to reduce the depth of the deflector so that the print head still fits behind the Duet box in its standard position, increase the number of deflector blades to make it quieter, and (as I said in my recent post) the clasps on Andy's original don't fit my fan well.
Andy has published the OpenScad files (and I have published the corresponding files for my variant), so you are free to do your own variant to suit your particular requirements.
August 10, 2014 05:26AM
Hi All,
I have 5 blade fan, but I like dc42's slim design so I thought I would give it a try. It works fantastic!
I was having a lot of trouble with severe warping in the corner near the duet board; you could feel the draft bouncing of the duet enclosure. With the deflector there is no longer any backwash, and no warping. It's also quieter (not that the noise was a problem...I like the sound of construction).
Great mod, thanks!!
Alex.
January 03, 2016 05:37AM
Hello,
I am actually looking for a new design for my Ormerods as the clip on designs do not work for my fans or at least for the Ormerod 2 fan. My Ormerod 2 uses another nozzle that needs not so much cooling, but I have too much backwash so even PLA warps.
Has anyone tested this design? looks wuite interesting:
[www.thingiverse.com]
Slicer: Simplify3D 4.0; sometimes CraftWare 1.14 or Cura 2.7
Delta with Duet-WiFi, FW: 1.20.1RC2; mini-sensor board by dc42 for auto-leveling
Ormerod common modifications: Mini-sensor board by dc42, aluminum X-arm, 0.4 mm nozzle E3D like, 2nd fan, Z stepper nut M5 x 15, Herringbone gears, Z-axis bearing at top, spring loaded extruder with pneumatic fitting, Y belt axis tensioner
Ormerod 2: FW: 1.19-dc42 on Duet-WiFi. own build, modifications: GT2-belts, silicone heat-bed, different motors and so on. Printed parts: bed support, (PSU holder) and Y-feet.
Ormerod 1: FW: 1.15c-dc42 on 1k Duet-Board. Modifications: Aluminium bed-support, (nearly) all parts reprinted in PLA/ ABS, and so on.
January 03, 2016 05:43AM
I gave up with clip-on designs because the clips broke. I now use four screws, which requires drilling 2 more holes in the heatsink and using longer screws, with nyloc nuts at the back of the 2 extra screws. See [www.thingiverse.com]. It's working well on my dual extrusion Ormerod, and I can't feel any backwash.
January 03, 2016 06:05AM
As I have another nozzle I would have the 4 screws. I needed 4 screws to securely connet the two pieces which hold the nozzle together. That would be not a big deal. I do not like the countersunk screw design otherwise I would have taken your design.
I guess I will first try this one:
The first design I posted above looks interesting because it transfers the air completely up, but maybe it blocks also too much.
July 25, 2017 07:49AM
How did that design work for you guys?
Also what is the latest update on this?
I see that you refer to the fan blowing but on my machine the fan seems to suck air from the three holes under by the print nozzle and then past the heat sink and out by the van.
Is this correct?
Treito
Edited 1 time(s). Last edit at 07/26/2017 11:29AM by Karoo Klong.
July 29, 2017 08:07PM
The fan should BLOW out of the 3 holes by the nozzle. The fan housing should have 2 arrows on it somewhere. One arrow shows the direction of the blades and the other shows the direction of the airflow. The airflow arrow should be pointing TO the heatsink.
Pete.
July 31, 2017 07:47AM
Thank you Pete
I checked if the fan sucks or blows.
I was misled by the backwash from the fan. It does indeed suck air and blow it down to the nozzle.
I also understand the backwash problem much better now.
Peterdl
Pete.
