The bed should never have been created with MDF January 01, 2014 01:53PM |
Re: The bed should never have been created with MDF January 01, 2014 02:06PM |
Re: The bed should never have been created with MDF January 01, 2014 02:28PM |
Re: The bed should never have been created with MDF January 01, 2014 02:33PM |
Re: The bed should never have been created with MDF January 01, 2014 02:34PM |
Re: The bed should never have been created with MDF January 01, 2014 02:42PM |
Re: The bed should never have been created with MDF January 01, 2014 02:48PM |
Re: The bed should never have been created with MDF January 01, 2014 02:53PM |
Re: The bed should never have been created with MDF January 01, 2014 03:26PM |
Re: The bed should never have been created with MDF January 01, 2014 03:57PM |
Re: The bed should never have been created with MDF January 01, 2014 04:09PM |
davem
....The printer relies on tolerances of less than 0.4mm and yet the corners of the bed will flex up and down 10mm!
The best way I have found to set the bed and Z axis height up is to try to manually adjust the position of the bed to get an equal dimension at all four corners of the bed. To measure the gap I have used the shank of a 10mm drill bit between the bed and the nozzle and adjusted the Z axis lead screw by hand. Once I have the four corners as equal as possible you can then move the x and y axis to the centre of the bed and set the Z height using the drill bit. Once there is slight contact between the nozzle and drill bit set G92 Z10.
Dave M
Re: The bed should never have been created with MDF January 01, 2014 04:15PM |
Re: The bed should never have been created with MDF January 01, 2014 04:46PM |
Re: The bed should never have been created with MDF January 01, 2014 07:55PM |
Rory166
Andy
I cant wait for your Carbon fiber Nomex foam sanwich heatbed support design to appear. Come on now you started so you need to finish!
Re: The bed should never have been created with MDF January 01, 2014 08:56PM |
Re: The bed should never have been created with MDF January 02, 2014 02:40AM |
Re: The bed should never have been created with MDF January 02, 2014 10:14AM |
dc42
Surely the bed is essentially supported at 3 points, with the two outer corners not really providing support? I'm tempted to remove those 2 screws completely. With the printing plate made of rigid glass, and the heater PCB being rigid too, I don't think it makes much sense to support it at more than 3 points. It is theMDFplywood ribs that keep the 3 support points stable relative to the bearings - and I think they do that quite well.
Re: The bed should never have been created with MDF January 02, 2014 11:55AM |
Re: The bed should never have been created with MDF January 02, 2014 03:46PM |
Re: The bed should never have been created with MDF January 02, 2014 04:31PM |
dc42
Thinking further about it, I'll replace the 2 outside front screws by short ones, that clamp the aluminium and bed heater together but do not penetrate the MDF.
Re: The bed should never have been created with MDF January 02, 2014 04:33PM |
Re: The bed should never have been created with MDF January 02, 2014 04:41PM |
Re: The bed should never have been created with MDF January 02, 2014 04:46PM |
KK
...As mentioned else where by dc42 White PVC insulation tape works much better than the aluminium foil on the corners of the glass...
Kevin
Ormerod 245 (in South Africa)
Re: The bed should never have been created with MDF January 02, 2014 04:53PM |
Rory166
Looking at the build instructions I cannot see any mention of the fifth mounting screw...
Rory
Re: The bed should never have been created with MDF January 02, 2014 05:06PM |
Re: The bed should never have been created with MDF January 03, 2014 02:28AM |
Re: The bed should never have been created with MDF January 03, 2014 04:48AM |
Re: The bed should never have been created with MDF January 03, 2014 04:51AM |
Re: The bed should never have been created with MDF January 03, 2014 06:22AM |
markbee
What is the thickness of the plexiglas you are using and what type?
Markus
