Re: The Progression of Kit278 January 10, 2014 08:16AM |
Re: The Progression of Kit278 January 10, 2014 09:00AM |
Re: The Progression of Kit278 January 10, 2014 09:36AM |
Re: The Progression of Kit278 January 10, 2014 09:38AM |
Re: The Progression of Kit278 January 13, 2014 05:28AM |
Re: The Progression of Kit278 January 13, 2014 07:10AM |
Re: The Progression of Kit278 January 13, 2014 09:36AM |
Re: The Progression of Kit278 January 13, 2014 05:10PM |
Re: The Progression of Kit278 January 13, 2014 05:23PM |
victors
Another worrying thing. The electronics also heat up. The CPU is now sitting at 47C. Max temperature over entire board is 55C. I think you guys need to rethink the bed-heater bus plus electronics away from the Duet.
Re: The Progression of Kit278 January 14, 2014 02:53AM |
Re: The Progression of Kit278 January 14, 2014 03:46AM |
victors
So my conclusion is that the PC power supply sucks! Big time! Sorry RRP, it does.
victors
Re: The Progression of Kit278 January 14, 2014 04:16AM |
Re: The Progression of Kit278 January 14, 2014 06:49AM |
Re: The Progression of Kit278 January 14, 2014 07:02AM |
Re: The Progression of Kit278 January 14, 2014 07:13AM |
Re: The Progression of Kit278 January 14, 2014 07:27AM |
Re: The Progression of Kit278 January 14, 2014 08:23AM |
tru168
Why not Reprap pro stop using PC PSU as standard power supply and include an industrial type together with kit set?
Re: The Progression of Kit278 January 14, 2014 08:24AM |
reprappro
We have been supplying two different ATX power supplies. The Alpine is actually the higher output one, and should say on it that it supplies +12V with 30A. The Ace PSU is lower rated, at 22A. However, the machine should not draw even close to this much current, at 12V.
reprappro
So it's all about the bed heater. Check the resistance of your bed; it should be around 1.2 or 1.3 ohms.
At 12V, with a heatbed resistance of around 1.3ohms, the bed draws 9.23A, so there is 110.7W of power going to the bed.
4. Check the resistance of the heated bed. Turn the power to the printer off, disconnect the two 2x6 IDC connectors on the bed PCB, and measure the resistance between the solder pads on the bed PCB with a good digital multimeter. It should be around 1.2 to 1.3 ohms. If it is lower, it will use more current, and could lead to the PSU being overloaded.
reprappro
5. Unplug the hot end heater plug from the Duet board (brown and yellow), and measure the resistance of the hot end heater; it should be around 3 ohms. Again, check the hot end connector for good connections - it's possible the pins have been pushed out.
Re: The Progression of Kit278 January 14, 2014 08:45AM |
Re: The Progression of Kit278 January 14, 2014 01:59PM |
Re: The Progression of Kit278 January 14, 2014 02:03PM |
Re: The Progression of Kit278 January 14, 2014 03:02PM |
Re: The Progression of Kit278 January 14, 2014 03:28PM |
Re: The Progression of Kit278 January 14, 2014 03:38PM |
Re: The Progression of Kit278 January 14, 2014 03:42PM |
Re: The Progression of Kit278 January 14, 2014 04:14PM |
Re: The Progression of Kit278 January 14, 2014 04:30PM |
Re: The Progression of Kit278 January 14, 2014 04:45PM |
