Power supply regulation January 03, 2014 07:43PM |
Re: Power supply regulation January 04, 2014 12:21AM |
Re: Power supply regulation January 04, 2014 03:10AM |
Re: Power supply regulation January 04, 2014 04:42AM |
Re: Power supply regulation January 04, 2014 06:31AM |
Yes unfortunately, 450W was the highest spec'd part I could find in any doc. The V1.3 is very different. The minimum currents were the same for the range 220 to 450W but you are correct "what happens outside that range"?Quote
Rory166
It would seem from your figures that the Ormorod just fails to provide the minimum load required. However it is a 550W ATX so may have different specs.
Rory
Re: Power supply regulation January 04, 2014 07:08AM |
Re: Power supply regulation January 04, 2014 07:31AM |
Admin Registered: 17 years ago Posts: 7,879 |
Re: Power supply regulation January 04, 2014 07:58AM |
Re: Power supply regulation January 04, 2014 09:17AM |
Re: Power supply regulation January 04, 2014 09:41AM |
Re: Power supply regulation January 04, 2014 11:03AM |
Re: Power supply regulation January 04, 2014 02:54PM |
Once you move away from ATX form factors then costs start to rise.Quote
kwikius
What would be nice would be a sweet little PSU that slides in under the front of the machine under the print bed. The separate box with the ATX PSU is a PITA.
Only saying But if anyone knows of one that would fit...
regards
Andy
Re: Power supply regulation January 04, 2014 03:25PM |
Re: Power supply regulation January 05, 2014 08:45AM |
