"S" Axis.... Hot end Rocking - SOLVED... I hope.... January 06, 2014 04:25AM |
Re: "S" Axis.... Hot end Rocking - SOLVED... I hope.... January 06, 2014 05:07AM |
Re: "S" Axis.... Hot end Rocking - SOLVED... I hope.... January 06, 2014 06:00AM |
Re: "S" Axis.... Hot end Rocking - SOLVED... I hope.... January 06, 2014 01:55PM |
Re: "S" Axis.... Hot end Rocking - SOLVED... I hope.... January 06, 2014 04:48PM |
Re: "S" Axis.... Hot end Rocking - SOLVED... I hope.... January 07, 2014 02:42PM |
Re: "S" Axis.... Hot end Rocking - SOLVED... I hope.... January 08, 2014 04:24AM |
Re: "S" Axis.... Hot end Rocking - SOLVED... I hope.... January 08, 2014 04:57AM |
Re: "S" Axis.... Hot end Rocking - SOLVED... I hope.... January 08, 2014 05:44AM |
Re: "S" Axis.... Hot end Rocking - SOLVED... I hope.... January 08, 2014 06:34AM |
Re: "S" Axis.... Hot end Rocking - SOLVED... I hope.... January 08, 2014 09:20AM |
Re: "S" Axis.... Hot end Rocking - SOLVED... I hope.... January 08, 2014 09:47AM |
Re: "S" Axis.... Hot end Rocking - SOLVED... I hope.... January 08, 2014 10:32AM |
Re: "S" Axis.... Hot end Rocking - SOLVED... I hope.... January 08, 2014 10:50AM |
dc42
My x-plate is only 4.65mm thick. If it's meant to be 5mm then this partially explains why a 9mm x-runner bearing is too small on my build. The original x-plate I received was only slightly thicker, 4.70mm.
Re: "S" Axis.... Hot end Rocking - SOLVED... I hope.... January 08, 2014 10:52AM |
Re: "S" Axis.... Hot end Rocking - SOLVED... I hope.... January 08, 2014 11:29AM |
tim_h
Hmm, just thinking out loud, but it's strange that yours is convex along the back, mine was concave and gregstah's was S shaped?
This part of the design really needs improving otherwise the head will never stay at the same height along the x axis.
I agree that it the laser cut parts should be fixed together better, but not sure if extra screws or glueing are the best option, maybe both? It needs to be straight and remain straight when assembled.
Re: "S" Axis.... Hot end Rocking - SOLVED... I hope.... January 08, 2014 11:35AM |
Re: "S" Axis.... Hot end Rocking - SOLVED... I hope.... January 08, 2014 11:43AM |
dc42
Andy, what sort of glue do you use? I've heard that the only really effective glue for acrylic is acrylic monomer,
