Commissioning - cannot talk to Due January 06, 2014 05:19PM |
Re: Commissioning - cannot talk to Due January 06, 2014 05:31PM |
Re: Commissioning - cannot talk to Due January 06, 2014 05:38PM |
Re: Commissioning - cannot talk to Due January 06, 2014 06:32PM |
Re: Commissioning - cannot talk to Due January 06, 2014 06:49PM |
Re: Commissioning - cannot talk to Due January 06, 2014 07:01PM |
Re: Commissioning - cannot talk to Due January 06, 2014 07:34PM |
Re: Commissioning - cannot talk to Due January 06, 2014 08:24PM |
Re: Commissioning - cannot talk to Due January 07, 2014 05:58AM |
Re: Commissioning - cannot talk to Due January 07, 2014 07:20AM |
Re: Commissioning - cannot talk to Due January 07, 2014 09:10AM |
Re: Commissioning - cannot talk to Due January 07, 2014 09:34AM |
Re: Commissioning - cannot talk to Due January 07, 2014 09:52AM |
Re: Commissioning - cannot talk to Due January 07, 2014 10:45AM |
Re: Commissioning - cannot talk to Due January 07, 2014 11:06AM |
Re: Commissioning - cannot talk to Due January 07, 2014 02:28PM |
alanbattersby
I am using ubuntu 13.10 is it a problem with the OS?
#! /usr/bin/env sh cd ~/Downloads/arduino-1.5.5 sudo ./arduino
Re: Commissioning - cannot talk to Due January 12, 2014 04:52AM |
Re: Commissioning - cannot talk to Due January 12, 2014 05:12AM |
Re: Commissioning - cannot talk to Due January 12, 2014 05:23AM |
Re: Commissioning - cannot talk to Due January 12, 2014 06:49AM |
Re: Commissioning - cannot talk to Due January 12, 2014 09:30AM |
Re: Commissioning - cannot talk to Due January 12, 2014 11:02AM |
Re: Commissioning - cannot talk to Due January 12, 2014 11:09AM |
Re: Commissioning - cannot talk to Due January 12, 2014 11:22AM |
Re: Commissioning - cannot talk to Due January 12, 2014 11:28AM |
Re: Commissioning - cannot talk to Due January 12, 2014 11:30AM |
Re: Commissioning - cannot talk to Due January 12, 2014 01:19PM |
In another post (long since lost!) I pointed out that the USB socket housing and the network socket housing are NOT grounded on the DUET. I questioned this, but searches on the Internet do not confirm what is correct, although connecting to ground via a ferrite is common.Quote
droftarts
2. USB socket on the board is dodgy, as suggested before. Check if all four pins are soldered - these not only provide support for the socket, but also ground it, so you may have problems if none of them are soldered
Re: Commissioning - cannot talk to Due January 12, 2014 01:55PM |
Treth
The network connector housing I also believe should be grounded.
Just for reference the SD card housing IS connected to ground.
Re: Commissioning - cannot talk to Due January 12, 2014 02:24PM |
Hi Ian, I'm new to KiCAD and agree what you say about the schematic, but looking at the PCB board layout, I see that the screen for the USB and network are not connected. All the through holes seem to be floating.Quote
droftarts
Treth
I've just had a look at the schematic [github.com] page 5, and it would appear that the USB 'shield' is grounded on the board. There is the problem of creating an earth loop when the other end of the USB is grounded, I know, so yes, it would be good to get some feedback from EEs as to whether this is a good idea or not. This has existed in previous reprap electronics, and the danger of a ground loop has, I suppose, been there. But then how do commercial companies, eg Epson, cope with this when they build a USB printer?
The SD card socket and Ethernet port also seem to be grounded.
Ian
RepRapPro tech support
Re: Commissioning - cannot talk to Due January 12, 2014 02:28PM |
