Firmware change proposals January 07, 2014 11:42AM |
Re: Firmware change proposals January 07, 2014 11:48AM |
Re: Firmware change proposals January 07, 2014 12:01PM |
Re: Firmware change proposals January 07, 2014 12:50PM |
Re: Firmware change proposals January 07, 2014 12:59PM |
Re: Firmware change proposals January 07, 2014 10:43PM |
Re: Firmware change proposals January 08, 2014 02:25AM |
Re: Firmware change proposals January 08, 2014 02:09PM |
Re: Firmware change proposals January 08, 2014 02:23PM |
Re: Firmware change proposals January 08, 2014 02:26PM |
chriscain
G92 does not work correctly which is not really much of a problem once you realise what is going wrong
chriscain
I am going to have a try to fix these and would be interested also in what the procedure/feeling is for user contributed code to the RepRapFirmware tree is.
Re: Firmware change proposals January 08, 2014 05:23PM |
Re: Firmware change proposals January 08, 2014 06:05PM |
Re: Firmware change proposals January 08, 2014 06:15PM |
droftarts
Re Z probing; perhaps a better method would be that it descends fast, even if it passes the value set, but then does a move up, then back down slow. This is the usual homing behaviour on other repraps. I'll add it to the list....
Re: Firmware change proposals January 09, 2014 05:13AM |
Re: Firmware change proposals January 09, 2014 05:51AM |
markm
It would be preferable to home the Z axis in the 'up' direction (Z+) to remove backlash, so a slight overshoot and going back up to position be quite good.
Re: Firmware change proposals January 09, 2014 06:14AM |
Re: Firmware change proposals January 09, 2014 06:25AM |
Re: Firmware change proposals January 09, 2014 06:46AM |
tim_h
I really like the idea of an external control panel, ideally to be able to inch and home the axes, set and check temps and to run gcodes from SD card.
Re: Firmware change proposals January 09, 2014 07:59AM |
Re: Firmware change proposals January 09, 2014 08:16AM |
Re: Firmware change proposals January 09, 2014 09:12AM |
reprappro
The idea of adding ethernet and a control panel is that you can control the printer from your mobile device - we don't have any plans to add a display. However, SPI is enabled on the board - it controls the stepper drivers (so Adrian tells me). We think it's probably broken out to some pins, but you'll have to refer to the schematics.
Ian
RepRapPro tech support
Re: Firmware change proposals January 10, 2014 03:29AM |
