Heads up - Driver install issue January 07, 2014 01:45PM |
Re: Heads up - Driver install issue January 07, 2014 05:01PM |
Re: Heads up - Driver install issue January 07, 2014 05:02PM |
dmould
I've already sent an email to the RepRap support team, but just a heads-up that the Arduino driver will no longer install on Windows. The reason is that its certificate is not dated, which results in Windows refusing to install it after 2013. The quick & dirty workaround is to reset your PC clock to 2013, install the driver, after which you can change the clock back to the correct date. As a permanent solution, the certificate needs to be dated and re-signed. Obviously only affects people who are installing the driver after the new year (as I needed to do today after moving the Ormerod to a different PC (running Win 8). The annoying thing is that Windows doesn't give any clue as to why the install failed, so I suspect many people commissioning the Ormerod for the first time are in for a frustrating experience!
Re: Heads up - Driver install issue January 08, 2014 05:37AM |
droftarts
Thanks for the heads up - I'll try and sort this out tomorrow. Is it just a Windows 8 problem, or Windows 7 too?
Ian
RepRapPro tech support
Re: Heads up - Driver install issue January 08, 2014 09:17AM |
Re: Heads up - Driver install issue January 08, 2014 09:55AM |
Re: Heads up - Driver install issue January 11, 2014 10:23AM |
Re: Heads up - Driver install issue January 11, 2014 11:17AM |
Re: Heads up - Driver install issue January 11, 2014 11:24AM |
Re: Heads up - Driver install issue January 11, 2014 11:33AM |
Re: Heads up - Driver install issue January 11, 2014 12:23PM |
Re: Heads up - Driver install issue January 11, 2014 01:10PM |
Re: Heads up - Driver install issue January 13, 2014 11:49AM |
Re: Heads up - Driver install issue January 13, 2014 12:20PM |
