Re: New Ormerod Web Interface - WIP January 11, 2014 08:45AM |
droftarts
The network framework is something we're looking at, but changing it drastically could introduce other problems. One left-field suggestion is the QP framework [en.wikipedia.org]
I know some people on here have experience of these sort of chips *cough* dc42 *cough* . Any other preferences/suggestions?
Re: New Ormerod Web Interface - WIP January 11, 2014 09:01AM |
iamburny
Going to try Printing via Web sent Gcodes see how that goes.
Re: New Ormerod Web Interface - WIP January 11, 2014 09:46AM |
dc42
iamburny
I suggest you try "printing" circle.g initially. If it works but in jerky steps, I have some firmware changes that may fix that. I made them to get print via USB working properly (it turned out that Pronterface needs fixing too), but they are applicable to printing over the web interface too.
Re: New Ormerod Web Interface - WIP January 11, 2014 09:50AM |
iamburny
I think the main problem with this is going to be lack of feedback, as i'm not going to be able to tell if the buffer is full or able to accept another command, i'd thought about estimating the time each command will take based on feed rate and distance to travel, this however is hardly ideal. getting web responses from G codes seems to be key to unlocking alot of enchanced functionality.
Re: New Ormerod Web Interface - WIP January 12, 2014 03:14AM |
Re: New Ormerod Web Interface - WIP January 12, 2014 05:24AM |
Re: New Ormerod Web Interface - WIP January 12, 2014 06:50AM |
Re: New Ormerod Web Interface - WIP January 14, 2014 01:24PM |
Re: New Ormerod Web Interface - WIP January 18, 2014 03:36AM |
Re: New Ormerod Web Interface - WIP January 18, 2014 05:23AM |
Re: New Ormerod Web Interface - WIP January 18, 2014 01:00PM |
Re: New Ormerod Web Interface - WIP January 18, 2014 01:08PM |
Woohooo! Thank you Matt! January 21, 2014 05:06AM |
Re: Woohooo! Thank you Matt! January 21, 2014 05:43AM |
Re: New Ormerod Web Interface - WIP January 21, 2014 02:10PM |
Re: New Ormerod Web Interface - WIP January 21, 2014 02:29PM |
bobtidey
One longer term suggestion which would be nice would be to be able to update any of the SD card files, e.g changing things like config.g. That would then avoid the need to take the card in and out. I expect that would need firmware changes as well.
Re: New Ormerod Web Interface - WIP January 21, 2014 03:08PM |
bobtidey
My question is to do with the local and remote versions of reprap.htm. I can run either as machine is on internet capable network and my local Ubuntu USB control PC has a web server. Currently there seems to be some functional differences between the two versions as well as the secondary links. For example, the local version has extra bed compensation controls.
bobtidey
Is it correct to say the local one has more recent updates?
bobtidey
Also the remote minimised version still seemed to have local link addresses at the moment.
bobtidey
Re: New Ormerod Web Interface - WIP January 21, 2014 03:53PM |
Re: New Ormerod Web Interface - WIP January 22, 2014 06:34AM |
Re: New Ormerod Web Interface - WIP January 22, 2014 07:20AM |
Re: New Ormerod Web Interface - WIP January 22, 2014 07:31AM |
droftarts
Great! Pull request?
Ian
RepRapPro tech support
Re: New Ormerod Web Interface - WIP January 22, 2014 03:27PM |
Re: New Ormerod Web Interface - WIP January 22, 2014 03:49PM |
Re: New Ormerod Web Interface - WIP January 22, 2014 04:48PM |
Re: New Ormerod Web Interface - WIP January 22, 2014 04:57PM |
Re: New Ormerod Web Interface - WIP January 22, 2014 05:23PM |
Re: New Ormerod Web Interface - WIP January 22, 2014 05:50PM |
Re: New Ormerod Web Interface - WIP January 23, 2014 02:17PM |
Re: New Ormerod Web Interface - WIP January 23, 2014 03:25PM |
Re: New Ormerod Web Interface - WIP January 23, 2014 03:56PM |
