Re: New Ormerod Web Interface - WIP February 08, 2014 07:24AM |
Re: New Ormerod Web Interface - WIP February 08, 2014 02:35PM |
Re: New Ormerod Web Interface - WIP February 08, 2014 02:50PM |
Re: New Ormerod Web Interface - WIP February 08, 2014 03:53PM |
Re: New Ormerod Web Interface - WIP February 08, 2014 05:31PM |
DC42'Besides installing one of my versions of the firmware (and then testing it with Pronterface if you like), all you need to do to get Matt's web interface working is:
- Download reprap.remote.htm from Matt's github repository [github.com
- Rename it to reprap.htm
- Use Pronterface option File->Upload reprap.htm to upload it to the SD card (or take the SD card out and do it manually).
This assumes that the computer you use to control the Ormerod has Internet access. You only need to run a local web server if it won't.
Re: New Ormerod Web Interface - WIP February 08, 2014 07:38PM |
Re: New Ormerod Web Interface - WIP February 08, 2014 09:45PM |
dc42
...and I've just published 57l-dc42 at [github.com] (follow the link and press the Raw button to download). Improvements in this release:
1. When G92 is used, the bed transform is applied to the requested coordinates. This means that for example, if you do G92 Z0 then the firmware now assumes the head really is at Z=0 (i.e. just touching the bed), and will report the current coordinates with Z=0 instead of assuming that the bed transform still needs to be applied.
2. You can now run the G32 bed-probing procedure without first homing the Z-axis. In this case, the Z=0 position will be determined by the first probe.
Re: New Ormerod Web Interface - WIP February 09, 2014 03:47AM |
rm2014
dc42 Will the existing 3 SD files work with this firmware??
Re: New Ormerod Web Interface - WIP February 09, 2014 08:21AM |
Re: New Ormerod Web Interface - WIP February 09, 2014 08:34AM |
Re: New Ormerod Web Interface - WIP February 09, 2014 08:45AM |
davetech
Hi Matt
Everything is ok now I'm enclosing a current picture of my omerod with a couple of mods
Re: New Ormerod Web Interface - WIP February 09, 2014 08:51AM |
Re: New Ormerod Web Interface - WIP February 09, 2014 09:34AM |
appjaws1
Thank you for this interface. I do like the design and layout, however, I have a few problems:-
appjaws1
1. When I open the page in chrome it opens fine but when I click connect the button turns green and says connected but nothing happens, no controls are working it's all greyed out. If I then click online to go offline the button goes red and says offline, then I click again and this time all items are useable.
appjaws1
2. Using your procedure I end up with the nozzle too low to print. so I am having to zero Z - G92 Z0 run setbed.g - G32 and then print.
appjaws1
3. Update to SD card is not working, I drop a file and the message says that it is loading but nothing happens, I end up with a zero file.
appjaws1
4. I took out the SD card and loaded on new g files, put the card back and started Omerod and the interface but the new files were not shown.
appjaws1
5. I tried to print a replacement part and it failed due to the filament not sticking. I tried this a number of times with different parts and cleaning the bed each time. I then decided to try the same print from Pronterface and it is printing perfectly. Why this should work from Pronterface and not your interface I don't know but an willing to try and resolve this issue with your help.
Re: New Ormerod Web Interface - WIP February 09, 2014 11:11AM |
Re: New Ormerod Web Interface - WIP February 09, 2014 11:16AM |
appjaws1
Thank you for the information. I will start from scratch in the morning and re-calibrate G31 and recheck my other findings. I'm sure I tried the refresh button and nothing happened, the list remained the same.
Paul
Re: New Ormerod Web Interface - WIP February 10, 2014 08:08AM |
Re: New Ormerod Web Interface - WIP February 10, 2014 08:36AM |
Re: New Ormerod Web Interface - WIP February 10, 2014 02:54PM |
Re: New Ormerod Web Interface - WIP February 10, 2014 03:05PM |
Re: New Ormerod Web Interface - WIP February 10, 2014 03:12PM |
Re: New Ormerod Web Interface - WIP February 10, 2014 06:25PM |
Re: New Ormerod Web Interface - WIP February 11, 2014 07:26AM |
Re: New Ormerod Web Interface - WIP February 11, 2014 07:53AM |
Re: New Ormerod Web Interface - WIP February 11, 2014 08:07AM |
Re: New Ormerod Web Interface - WIP February 11, 2014 08:49AM |
Re: New Ormerod Web Interface - WIP February 11, 2014 10:51AM |
Re: New Ormerod Web Interface - WIP February 11, 2014 11:19AM |
Re: New Ormerod Web Interface - WIP February 12, 2014 02:56AM |
Re: New Ormerod Web Interface - WIP February 12, 2014 04:24AM |
Re: New Ormerod Web Interface - WIP February 12, 2014 04:59AM |
