Re: New Ormerod Web Interface - WIP February 12, 2014 05:12AM |
Re: New Ormerod Web Interface - WIP February 12, 2014 05:50AM |
See attached file (i don't even know, if its the right file...)Quote
dc42
Sven, I'd like to work out what is going wrong, not least because RRP has recently adopted my firmware changes and Matt's web interface (so far only into the Duet branch). I'm running with Win 7 Pro x64. First some information I would like:
1. When you try to connect using Matt's interface and 057m-dc42 firmware, what exactly happens?
When i try to connect (like i did ever before), the chrome browser is working some seconds, then i get a message from chrome like "connection failed. The remote host or network you tried to contact may be down (113) No route to host.
2. Are you using the latest version of Matt's web interface?
Yes, i'm using the last version, i tried both, the reprap.remote.htm and reprap.remote.min.htm. (Both worked find on last firmware 57j-dc42)
3. What is your network configuration: how are your Ormerod and your PC connected to each other/your router?
This part is not my favourite, so our it-specialist made the connection between my pc and the printer. He just left the room, so i couldn ask him now, but he teste a lot of things, he pinged the printer and checked the network. In hin opinion it is no network fault, he suspects a mistake in the firmware or in the configuration of the htm-files. If this would be the reason, i wonder no other has this issue..
4. Are you using a local web server or the remote version of reprap.htm?
I use the remote version, like the last days
5. If this problem is happening with Matt's latest web interface, please can you do one or both of the following:
(a) Connect via Pronterface, send M111 S1, then try to use the web interface (causing the problem to occur), then disconnect Pronterface, then copy the text from the Pronterface message log window into an editor and post it.
I will post the text a.s.a.p. at the moment i'm printing via pronterface, it will take some time...
(b) Install Wireshark on your PC, capture the network traffic to the Ormerod when the problem occurs, save the capture to file, and post it.
Re: New Ormerod Web Interface - WIP February 12, 2014 05:54AM |
Re: New Ormerod Web Interface - WIP February 12, 2014 09:59AM |
Re: New Ormerod Web Interface - WIP February 12, 2014 10:04AM |
Re: New Ormerod Web Interface - WIP February 12, 2014 10:38AM |
Mr.Burns
Its time or another update:
Now, after putting matts new Ormerod Web Interface into the "www"-folder on my sd-card, i'm able to get on the web interface, but now i've got a new problem. I can't push any buttom, they are all pale! I only can switch betwenn "Control", "Print Status",...
Re: New Ormerod Web Interface - WIP February 12, 2014 11:15AM |
Re: New Ormerod Web Interface - WIP February 12, 2014 11:29AM |
Re: New Ormerod Web Interface - WIP February 12, 2014 11:37AM |
Re: New Ormerod Web Interface - WIP February 12, 2014 12:03PM |
Re: New Ormerod Web Interface - WIP February 12, 2014 12:20PM |
Re: New Ormerod Web Interface - WIP February 12, 2014 12:27PM |
Re: New Ormerod Web Interface - WIP February 12, 2014 12:35PM |
Re: New Ormerod Web Interface - WIP February 12, 2014 03:14PM |
Re: New Ormerod Web Interface - WIP February 12, 2014 03:24PM |
Re: New Ormerod Web Interface - WIP February 12, 2014 03:26PM |
Re: New Ormerod Web Interface - WIP February 12, 2014 03:42PM |
Cash
I have not completely understood why the .js files could not be hostet on the Ormerod itself and why i will need a separate web server. Could anyone explain this for me? The reprap.js is already located on the sd card inside the js folder, why could it not be used?
Re: New Ormerod Web Interface - WIP February 12, 2014 07:11PM |
Re: New Ormerod Web Interface - WIP February 13, 2014 01:28AM |
iamburny
@Mikeyblueeyes/Mr.Burns - Are you using chrome and the latest version I released today v0.65? remote or local version?
you can see the Google Chrome Javascript console by pressing Ctrl-Shift-J, if there is a Javascript error there will be a small red cross in the top right which you can click on to get more info, this info would help greatly in diagnosing your problems.
Matt
Re: New Ormerod Web Interface - WIP February 13, 2014 02:39AM |
Re: New Ormerod Web Interface - WIP February 13, 2014 02:59AM |
Re: New Ormerod Web Interface - WIP February 13, 2014 03:29AM |
Re: New Ormerod Web Interface - WIP February 13, 2014 03:57AM |
Re: New Ormerod Web Interface - WIP February 13, 2014 04:18AM |
Re: New Ormerod Web Interface - WIP February 13, 2014 04:58AM |
Re: New Ormerod Web Interface - WIP February 19, 2014 02:53PM |
Re: New Ormerod Web Interface - WIP February 19, 2014 03:13PM |
Re: New Ormerod Web Interface - WIP February 20, 2014 09:02AM |
Re: New Ormerod Web Interface - WIP February 20, 2014 10:28AM |
Re: New Ormerod Web Interface - WIP February 20, 2014 12:48PM |
