Hot end overtemp shutdown January 08, 2014 02:39AM |
Re: Hot end overtemp shutdown January 08, 2014 03:25AM |
Re: Hot end overtemp shutdown January 08, 2014 03:52AM |
Re: Hot end overtemp shutdown January 08, 2014 04:02AM |
Re: Hot end overtemp shutdown January 08, 2014 04:05AM |
Excellent idea, the following are non-resetable but go a little higher to 240C trip temp (not max operating temp which some searches provide)Quote
dc42
I did some research on thermal fuses, however the highest holding temperature I found was 200C. This is a little too low even for PLA printing.
Re: Hot end overtemp shutdown January 08, 2014 04:08AM |
I found by thermistor a very tight fit in the block, but can see the heat shrink idea is good and I could also benefit from securing the connectors.Quote
kwikius
The first thing that springs to mind is a more precise way to secure the thermistor in the block. I secured mine by bending the leads around the block, but its not very satisfactory.
One option is to get some larger diameter heatshrink ( or something ) to act as a stop and put that on one lead so you can slide the thermistor in from one end to a known point. Then add clamps ( e.g screw terminals) somewhere to secure the other end. (EDIT: Both ends!) Maybe the bit of paxolin above the block could be extended to mount clamps on.
regards
Andy
Re: Hot end overtemp shutdown January 08, 2014 04:17AM |
Re: Hot end overtemp shutdown January 08, 2014 04:27AM |
Re: Hot end overtemp shutdown January 08, 2014 04:31AM |
Treth
dc42
[www.sinolec.co.uk]
These are AC current rated and I haven't investigated there DC performance (often a lower rating due to arcing)
Re: Hot end overtemp shutdown January 08, 2014 05:26PM |
Re: Hot end overtemp shutdown January 08, 2014 05:56PM |
Re: Hot end overtemp shutdown January 08, 2014 06:11PM |
Re: Hot end overtemp shutdown January 09, 2014 01:45AM |
Re: Hot end overtemp shutdown January 09, 2014 03:52AM |
Re: Hot end overtemp shutdown January 09, 2014 04:34AM |
Re: Hot end overtemp shutdown January 09, 2014 12:23PM |
Re: Hot end overtemp shutdown January 10, 2014 06:33PM |
Re: Hot end overtemp shutdown January 11, 2014 01:13PM |
Re: Hot end overtemp shutdown January 11, 2014 02:00PM |
Re: Hot end overtemp shutdown January 11, 2014 03:23PM |
Re: Hot end overtemp shutdown January 11, 2014 07:17PM |
Admin Registered: 18 years ago Posts: 7,883 |
Re: Hot end overtemp shutdown January 15, 2014 09:01AM |
