Y axis disturbance - when "holes" made - SOLVED
Posted by Astute
January 09, 2014 01:47PM
Finally getting some prints out of the printer. All fairly ok there.
Figured out that printing from the SD card is by far the best.
BUT: When I printed the hook - the y axis slides a bit - making the hook like the picture. The "slide" occurs when the holes are started and ended.
This is only on the Y axis. If I print it via pronterface it does not have this issue (but not with a decent quality).
I printed 3 hooks and all have the exact same symptom.
Edited 1 time(s). Last edit at 01/11/2014 07:14AM by Astute.
open | download - WP_20140109_002.jpg (178.9 KB)
Re: Y axis disturbance - when "holes" made
January 09, 2014 01:50PM
Hi Astute,
either your y-axis is loose or you didn't compensate the axis?
Markus
XBee & electronics blog: [lookmanowire.blogspot.com]
January 09, 2014 02:54PM
Did everything.
When it prints via Pronterface - der is no slide at all.
When I SD print - I get the same result - the exact same place on the hook.
January 09, 2014 04:04PM
All my (very similar) Y axis problems were solved when I glued the belt to the carriage, even when it felt super tight it was still slipping sometimes. SD printing is faster so maybe that's why it only slips then.
January 09, 2014 04:06PM
Thx - will try ;-)
January 11, 2014 07:14AM
This fixed it !
