Printing layers in 60 microns - success January 11, 2014 10:44AM |
Re: Printing layers in 60 microns - success January 11, 2014 10:53AM |
Re: Printing layers in 60 microns - success January 11, 2014 10:57AM |
Re: Printing layers in 60 microns - success January 11, 2014 11:51AM |
Re: Printing layers in 60 microns - success January 11, 2014 12:08PM |
Re: Printing layers in 60 microns - success January 11, 2014 12:09PM |
Re: Printing layers in 60 microns - success January 11, 2014 12:21PM |
Re: Printing layers in 60 microns - success January 11, 2014 12:35PM |
Re: Printing layers in 60 microns - success January 11, 2014 12:40PM |
Re: Printing layers in 60 microns - success January 11, 2014 12:45PM |
Re: Printing layers in 60 microns - success January 11, 2014 05:15PM |
Re: Printing layers in 60 microns - success January 11, 2014 05:22PM |
Re: Printing layers in 60 microns - success January 11, 2014 05:29PM |
rayhicks
Will do DC - in the meantime, have you tried running your file from SD? It may prove enlightening...
Look, no bands! (well hardly any) January 11, 2014 05:34PM |
Re: Look, no bands! (well hardly any) January 11, 2014 05:39PM |
Re: Printing layers in 60 microns - success January 11, 2014 06:01PM |
Re: Look, no bands! (well hardly any) January 11, 2014 06:07PM |
Re: Printing layers in 60 microns - success January 11, 2014 06:35PM |
Re: Printing layers in 60 microns - success January 11, 2014 06:54PM |
Re: Printing layers in 60 microns - success January 11, 2014 07:44PM |
rayhicks
@ dc - indeed your file worked fine via usb or from SD, I've attached [attachment 24590 gearfail.gcode] a simple file that works over usb, but not from SD (the gears twitch when run from SD, but not from USB - note it seems to have always been the case that USB-based small Z steps worked), the gcodes file from the same stl file slic3d with a 0.3mm lift on retraction print properly from SD (ie the gears move properly)
Re: Printing layers in 60 microns - success January 11, 2014 08:36PM |
Re: Printing layers in 60 microns - success January 12, 2014 05:19AM |
Re: Printing layers in 60 microns - success January 12, 2014 06:23AM |
Re: Printing layers in 60 microns - success January 12, 2014 06:29AM |
Re: Printing layers in 60 microns - success January 12, 2014 07:01AM |
Re: Printing layers in 60 microns - success January 12, 2014 07:06AM |
droftarts
Try doing a 'vase' print. This is like a spiral print, so the Z axis is in constant motion, upwards, except for the first couple of layers (though it may be a victim of the Z-small-move bug). There's a blog post on this here: [slic3r.org]
Slic3r 1 rc2 has a tick box option for spiral vase now by the way, so pretty easy to slice them
Re: Printing layers in 60 microns - success January 12, 2014 07:13AM |
rayhicks
@ ian
droftarts
I've tried that, it did suffer from the problemSlic3r 1 rc2 has a tick box option for spiral vase now by the way, so pretty easy to slice them
Ray
Re: Printing layers in 60 microns - success January 12, 2014 07:16AM |
Re: Printing layers in 60 microns - success January 12, 2014 08:51AM |
Re: Printing layers in 60 microns - success January 12, 2014 09:11AM |
