Z lead screw nut thread stripped
Posted by arnaud31
Re: Z lead screw nut thread stripped
January 22, 2014 09:45AM
Ray
I used the new style nut trap STL and just cut a cube out of it to accommodate the new Z nut.
John
open | download - New Z nut trap3.stl (67.3 KB)
January 22, 2014 10:09AM
Thanks John,
I can mill some stock that'll fit that (but all my hex stock is imperial, which has stopped me doing it so far) - what did you use to edit the stl by the way? I haven't managed to find anything that lets me ...
Cheers
Ray
January 22, 2014 10:19AM
Ray
I use a package called TurboCad. I bought it originally to use with my CNC machine, mostly 2D work. But it also works fine with 3D objects and will import STL files and modify them.. I milled the brass down to 10x10x15 mm
John
January 22, 2014 10:26AM
Blender can also import STL files:
File->Import->STL
RS-Online Ormerod #263, Kossel mini with Minitronics, Prusa i3 MK2
January 22, 2014 10:40AM
Thanks for the pointers johneato and 3D-ES,
Ray
January 22, 2014 01:50PM
thanks again johneato - I printed out your edited stl and found it's a snug fit for the flats of my 3/8" hex brass bar stock, so I tapped a chunk of that and it's all working great (I had to snap off the remaining bit of black acrylic that had been the nut trap on my machine, it may not have held on much longer judging by the ease with which it came away, so quite a timely mod)
cheers
Ray
January 22, 2014 02:13PM
Ray
Pleased to hear I was of some use to someone, the help has been mainly incoming so far.
I found the black acrylic had already broken on mine when I dismantled the z nut trap so that was another reason to replace it.
John
January 26, 2014 03:08PM
HI guys, just assembled my new "Green" Ormerod. Found out same problem, since first run Z screw was wobbling, due to Z gear tilting on the bearing. Just the time to print a couple of snowmans, the coat hook and the two sets of XYZ samples for compensation that I found out a lot of grinded metal powder all around. Unmounted all, cleaned, polished the screw with fine grinding paper. I found out too much play between gear and beating and some "bumps" inside it. I removed bumps on the bottom bearing shoulder in the gear, applied a turn of electrical insulating tape on the bearing and a small amount of MoS2 grease on the screw. Now it turns smoothly and quiely with very little woobling at the top. Get back to print, will you keep informed. Perhaps I will apply a longher bronze (not brass) nut, but I nedd to ask some colleagues in the factory to build it on a turning and milling machine.
Green Ormerod Fan
Improvements and tunings:
- aluminum bed with spring suspended bed and iamburny's Y belt tensioner
- masonstonehenge's spring loaded extruder with dc42's herringbone gears based on iamburny's design
- philiptemobster's extruder holder
- Abs made fan holder, X carriage and extruder
- 0.78 firmware
- dc42's IR sensor + led PCB
Tested and want to improve:
- laser cutting L-Cheapo attachement
WTD:
- double extruder (to use different support material)
January 26, 2014 03:25PM
I solved my z-screw wobble with the second replacement z-driven gear I printed. This time used a vice instead of a hammer to get the nut in the gear. I also replaced the threaded rod by a hardened steel one, and used a brass nut in the z-nut trap instead of a steel nut. And of course applied some light machine oil.
Edited 1 time(s). Last edit at 01/27/2014 04:54AM by dc42.
January 27, 2014 04:21AM
I found this M5 coupling on Ebay. I think its a HUCO coupling insert. The nut part is too large to fit the nut trap but I found that the serrated part fits without turning. See pic
(This is in the original "Special edition Ormerod" z nut trap on the acrylic x-rib). I also replaced the M5 rod with stainless steel and the action is silky smooth. I dont know if I quite trust the fit as shown, but if it shows signs of slipping then I will try to make a custom z nut trap which uses a clamp so that the coupling can be clamped firmly in position by the serrated part ( while allowing a bit of rotation around x and y for the wonky gears!) so removing any slop.
Feels good but not tested in anger yet!
ergards
Andy
Ormerod #318
www.zoomworks.org - Free and Open Source Stuff smiling smiley
January 27, 2014 04:57AM
I'm not sure I would want to clamp the nut. If something goes wrong and the machine tries to drive the print head down into the bed, currently the z-nut comes out of the bottom of the nut trap and no damage is done. This has happened several times to me, e.g. when the IR sensor wires have come off.
January 27, 2014 05:23AM
While I'm still busy looking for brass nut locally, ( but without luck yet ) my Z axis really noisy even I already replaced a new spare nut. ( my ormerod only printed 600gm of filaments so far )
I have some 623 ( 1033zz actually , its the same size ) bearings laid in my drawer for years, those are Japanese bearing. after I replace it, my Z axis become quiet and stable again.
Anyone of you have bearings problem yet? or just me ?
January 27, 2014 05:53AM
dc42
Good point! I will bear it in mind if I have to redesign it.
regards
Andy
Ormerod #318
January 27, 2014 11:31AM
dc42
I solved my z-screw wobble with the second replacement z-driven gear I printed.....
Great, but this design is so mechanically wrong, there is no reason at all to put strain on the z-screw and make it wobble - z-gear, z-driven gear and bearing should of cause be in the same horizontal level
Raise the bearing as needed, about 6mm as far as I remember, redesign the z-driven gear with a deeper hole, aka get the bearing in the center of the z-driven gear
Erik
January 27, 2014 04:42PM
I have found the cause of the wobble, at least on my printer. It is simply that the nut does not fit square on the threaded stud. Remove the screw nut assembly and If you rotate it between you fingers you will see the nut is not square with the screw. I tried with a longer nut and it wasn't square either. The problem is the quality of the nut and/or the quality of the screw. I suspect top quality nut and stud will solve this if you can find one...
January 27, 2014 05:52PM
Oh for a cnc machine.......
I would like one, but I think I'll save you for a cnc laser cutter first...
smileys with beer
