X Homing Problem January 14, 2014 05:12AM |
Re: X Homing Problem January 14, 2014 05:17AM |
JVMelo
If the extruder is place in the middle of the bed, when I do G28 X0, the Head goes away from the Z axis support and doesn't recognize the foil in the bed.
JVMelo
If the extruder is placed close to the Z axis support the G28 X0 command sends the head towards the Z axis support and finds the little piece of foil that I placed as suggested here in the forum.
Re: X Homing Problem January 14, 2014 06:09AM |
JVMelo
dc42
That is the correct behaviour.
dc42
That happens to me if the machine is in bright sunlight. Drawing the window blind avoids it. The problem is that the z probe reading (as returned by G31) is already higher than the threshold, which is 400 by default, or whatever you set it to in your G31 command.
Re: X Homing Problem January 14, 2014 06:27AM |
Re: X Homing Problem January 14, 2014 06:29AM |
Re: X Homing Problem January 14, 2014 06:30AM |
Re: X Homing Problem January 14, 2014 06:41AM |
Re: X Homing Problem January 14, 2014 07:08AM |
rayhicks
Hi JVMelo - the bed axes make sense if you stand at the end of the machine with the Y motor nearest to you and the Z post on the left and look down on the bed - 0,0 (x=0, y=0) is the bottom left of the bed looking from this position - so moving the head to X=0 sends it to the left, postive values send it across to the right. Positive values of Y move the table toward you, and have the effect that the head is moved upwards relative to the bed. Homing both Y and X moves the bed away from the Y motor, and moves the head towards the X motor.
arnaud31
JVMelo, judging by your question I am wondering whether you have made the same mistake as me.
Have you got the X-axis connector the right way around? If you look closely at the wiring page of the instruction X-axis connectors are inverted compared to X, Y and E servos.
For some time I had my connector the wrong way around and it would not home X. Instead is would go away from the Z axis and jam against the stop.
The Z-probe is used in a different way to home X, it does not look at the aluminium tape on the bed but instead a plastic tab on the Z-carrier.
dc42
The Z height at which you do x-homing should not matter provided it is at least 5mm or so from the bed, so that the IR reflected from the bed is below the threshold. The later firmware versions use a macro on the SD card to do x-homing, and that macro raises the head a few mm at the start and lowers it at the end. What firmware version are you using? Send an M115 command to find out. If you updated the firmware, did you also pick up the new files in the sys directory if the SD image?
Re: X Homing Problem January 14, 2014 08:49AM |
Re: X Homing Problem January 14, 2014 08:55AM |
Re: X Homing Problem January 14, 2014 11:55AM |
Re: X Homing Problem January 14, 2014 07:53PM |
TMD_RS436
the X stepper motor is connected the other way round
dmould
I printed a new X-carriage (on which the Z axis light probe mounts) in black plastic, it unexpectedly made all the difference to the Z homing reliability.
Re: X Homing Problem January 15, 2014 04:17PM |
dc42
One other thing I found today is that the sensor board screw holes are large enough to allow the sensor board to rotate a few degrees, so that the sensor face is not parallel to the bed. This causes a big reduction in its sensitivity.
