Newbie with a problem - can't get bed to heat up at all January 14, 2014 09:34AM |
Re: Newbie with a problem - can't get bed to heat up at all January 14, 2014 09:45AM |
Re: Newbie with a problem - can't get bed to heat up at all January 14, 2014 09:53AM |
Re: Newbie with a problem - can't get bed to heat up at all January 14, 2014 10:07AM |
Re: Newbie with a problem - can't get bed to heat up at all January 14, 2014 10:30AM |
Re: Newbie with a problem - can't get bed to heat up at all January 14, 2014 11:11AM |
Re: Newbie with a problem - can't get bed to heat up at all January 14, 2014 11:13AM |
Re: Newbie with a problem - can't get bed to heat up at all January 14, 2014 11:32AM |
Re: Newbie with a problem - can't get bed to heat up at all January 14, 2014 11:34AM |
Re: Newbie with a problem - can't get bed to heat up at all January 14, 2014 11:59AM |
Re: Newbie with a problem - can't get bed to heat up at all January 14, 2014 12:15PM |
Re: Newbie with a problem - can't get bed to heat up at all January 14, 2014 12:22PM |
Re: Newbie with a problem - can't get bed to heat up at all January 14, 2014 12:27PM |
Re: Newbie with a problem - can't get bed to heat up at all January 14, 2014 12:29PM |
MrCrispi
No sign of life on the bed at all - didn't even realise there were led's will further investigate wiring...
Re: Newbie with a problem - can't get bed to heat up at all January 14, 2014 12:31PM |
Re: Newbie with a problem - can't get bed to heat up at all January 14, 2014 12:37PM |
Re: Newbie with a problem - can't get bed to heat up at all January 14, 2014 12:42PM |
Re: Newbie with a problem - can't get bed to heat up at all January 14, 2014 01:11PM |
rayhicks
I think that you may have problem on your duet - the temperature should show as absolute zero if there's an open circuit - if yours isn't changing when you remove the thermistor then the resistance isn't being read properly.
I think someone had a similar issue, and (I think) dc42 remapped one of the pins - using a different pin for thermistor input may help you to get to the bottom of your problem too
Re: Newbie with a problem - can't get bed to heat up at all January 14, 2014 01:14PM |
MrCrispi
Thanks for all the help radian stick with me! When powered up I only have 3 LEDs showing on the duet board - two come on whenever the USB port is connected and the third (half way down between the USB port and the bottom of the board) comes on when the ATX is powered up - nothing else lit up at any time...
Re: Newbie with a problem - can't get bed to heat up at all January 14, 2014 01:20PM |
Re: Newbie with a problem - can't get bed to heat up at all January 14, 2014 01:21PM |
Re: Newbie with a problem - can't get bed to heat up at all January 14, 2014 01:31PM |
Re: Newbie with a problem - can't get bed to heat up at all January 16, 2014 05:49AM |
Re: Newbie with a problem - can't get bed to heat up at all January 16, 2014 05:58AM |
Re: Newbie with a problem - can't get bed to heat up at all January 16, 2014 06:26AM |
Re: Newbie with a problem - can't get bed to heat up at all January 16, 2014 06:30AM |
Re: Newbie with a problem - can't get bed to heat up at all January 16, 2014 07:25AM |
Re: Newbie with a problem - can't get bed to heat up at all January 16, 2014 07:52AM |
Re: Newbie with a problem - can't get bed to heat up at all January 16, 2014 07:57AM |
Re: Newbie with a problem - can't get bed to heat up at all January 16, 2014 09:13AM |
